Code blocks nested in lists render in editor as if at top-level
In a note, enter the following:
* Here is a list item
  ```text
  Here is a code block within that list item
I’d expect to see the code block rendered in the editor in a way that makes it clear the block is nested inside in the list, i.e. in a manner consistent with the preview view, which gets this right.
The code block is rendered with a background that isn’t indented, making it appear that the code block is a top-level item which happens to contain code where every line is indented.
Screenshot:
  • Operating system: MacOS 10.14.6
  • Obsidian version: 0.6.4
  • Using custom CSS: no
Here’s a screenshot of the preview view getting the rendering right:
Here’s a similar bug report: Syntax highlighting is broken for block quotes in bulleted lists — but I think it’s probably a different case.
I have this issue too, although in my case Obsidian fails to render indents altogether. I am on Windows 10 version 0.8.13.
@s-kyy, @gimboland would you mind checking whether you still have this issue in your builds?
editor mode works fine
preview mode eradicates indents
expected behaviour
preview and editor modes match.
I think in @flatline 's case you have to un-indent your lines like so:
**Title**
- Workflow
    - HTML
    - CSS
    - etc
Instead of indenting under the Title line like you did in your editor mode.
**Title**
    - Workflow
        - HTML
        - CSS
        - etc
The original post has a separate problem.
Thanks @s-kyy, I’ll try that out.
Update yes, user error!
How about in numbers lists? When I use the following setup:
1. Step one, this is the fist step
2. Step 2, do some code
```bash
    curl -V google.com
  3. I would like this to continue automaticlly, I had to insert `3.` at the beginning to continue the list. If I would add a new step after step 2 then step 3 would not be upped to 4
This breaks the numbering and renders the blok as top level:
Screenshot 2020-10-13 at 22.24.38
What I would like to see happen is that if I use a code blok in list that it ‘respects’ the list and renders in the list level like:
Screenshot 2020-10-13 at 22.26.08
Using build v0.9.4 on macOS
Ill re ask this question in a different way:
How do I do code block is a numberd list without breaking te list?
If I do:
1. One
2. Two
\```yaml
Dit is code
1. This breaks the list
(Also, the code block is wider then the list)
1. One
2. Two
	```yaml
	Dit is code
3. This breaks the list
This issue still exists in version v0.15.9.
For example, the following markdown code:
- Test
	```lisp
	 (unless (server-running-p)
	   (server-start))
The current obsidian shows in editing (live preview) mode:
Obviously, the code block is not indented
The current obsidian shows in reading mode:
The rendering behavior of reading mode is correct.
P.s. Typora is correct in its editing mode:
