Block-level properties: metadata below the note level
Properties in Obsidian exist at the note level. A note can have a status, a type, a project assignment – but the note is the smallest unit that can carry metadata. Everything below that level – sections, paragraphs, individual blocks – is invisible to the property system.
This creates friction in several workflows.
Technical documentation. A guide or reference document is rarely uniform. Some sections become outdated while others remain current. Some sections target beginners, others assume advanced knowledge. Some sections describe features introduced in a specific version. Currently, there’s no way to mark these distinctions at the section level. The entire document has one status, one audience, one version – even when different parts have different characteristics.
A practical example: A documentation file covers an API. Section A describes a stable endpoint, Section B describes a deprecated endpoint (removed in v3.0), Section C describes a new endpoint (added in v2.5). There’s no way to query “show me all deprecated sections across my documentation” or to mark Section B as deprecated: true, removed-in: v3.0 without creating a separate note for each section – which fragments the document unnaturally.
Long-form writing. A novel chapter or essay isn’t monolithic. Different passages may be in different states – one paragraph is polished, another needs revision, a third requires fact-checking. Different passages may have different characteristics worth tracking – POV shifts, timeline markers, connections to other parts of the manuscript.
A practical example: A scene contains a flashback embedded in present-time narration. The flashback paragraph should link to the event it references elsewhere in the manuscript. The surrounding paragraphs exist in a different timeline. Currently, this temporal structure can only be expressed through prose or comments – it’s not queryable, not filterable, not systematically trackable.
Reference materials. Notes that aggregate information from multiple sources – literature notes, research compilations, meeting notes with multiple topics – contain blocks with different provenance, different confidence levels, different relationships to other notes.
A practical example: A literature note contains five key claims extracted from a paper. Each claim has a different relationship to other notes in the vault – one supports a hypothesis, one contradicts it, one is tangential. At the note level, this nuance is invisible. The note links to other notes, but which part of the note relates to which other note is lost.
The fundamental issue: Obsidian treats notes as atomic units, but knowledge isn’t atomic. Notes contain structure – sections, paragraphs, blocks – and that structure carries meaning that the current property system can’t capture.
A system for attaching properties to blocks – paragraphs, sections, or any content chunk – with editor support for visibility and potential integration with query tools like Dataview.
Core concept
The idea extends the existing property system downward in granularity. Just as a note can carry frontmatter that describes the note as a whole, a block within that note could carry properties that describe just that block. These block-level properties would function independently of the note’s properties – a note might have status: complete while one of its sections has status: needs-update, because the document overall is finished but a specific section has fallen behind.
The key design questions center on how properties attach to blocks, how they’re displayed in the editor, and whether they become queryable.
For attachment, the system needs a clear way to associate a set of properties with a specific piece of content. This could work by extending existing block IDs, by wrapping content in a container syntax, or by using special comments that the parser recognizes. Each approach has trade-offs in terms of visual intrusiveness, compatibility with existing Markdown conventions, and ease of use.
For display, the goal is visibility without distraction. Properties should be accessible when needed – when editing, when reviewing structure, when looking for something that needs attention – but shouldn’t clutter the reading or writing experience. This suggests either a dimmed inline display that makes properties visible but visually secondary, or a hidden-by-default approach where properties reveal themselves on hover or through a dedicated panel.
For queryability, the full value emerges when block properties integrate with tools like Dataview. A query asking for “all blocks with status: deprecated” would return not notes, but specific sections within notes – with links that jump directly to the relevant block. This transforms how documentation can be maintained, how manuscripts can be tracked, how research can be organized. Instead of knowing “this note contains something deprecated,” the query shows exactly which section, in which document, needs attention.
Possible syntaxes
Several approaches could work. Each has trade-offs in readability, compatibility, and implementation complexity. Presenting three options for discussion:
Option A – Block-ID extension
Obsidian already supports block IDs with the ^block-id syntax for creating references to specific blocks. This existing infrastructure could be extended to carry properties alongside the ID. A section about installation could end with a line that both identifies the block and attaches metadata to it – marking it as needing an update, specifying which version it applies to, indicating its target audience. The syntax would feel familiar to anyone already using Dataview’s inline fields, but with the crucial difference that these properties attach to the specific block rather than the note as a whole.
The advantage of this approach is that it builds on existing behavior. Block IDs are already parsed and understood. The extension is conceptually minimal – just allowing more information to travel with the ID. The disadvantage is that it only works for blocks that have IDs, and it might create confusion with current block-reference behavior.
Option B – Wrapper syntax
An alternative approach uses explicit fences to wrap content and attach properties to it. Similar to how code blocks use triple backticks to fence code, a wrapper syntax could use a different marker to fence content that carries metadata. The opening fence would include the properties in an attribute syntax – key-value pairs that describe the wrapped content.
This approach provides clear visual boundaries. There’s no ambiguity about which content the properties apply to – everything between the opening and closing fence. It can wrap multiple paragraphs, entire sections, or even nested structures. The syntax resembles Pandoc’s fenced divs, which may be familiar to users coming from academic or technical writing backgrounds. The disadvantage is visual intrusiveness – the fences add lines to the document that aren’t content, and deeply nested wrappers could become hard to read.
Option C – Comment-based
A third approach hides properties in special comments that the parser recognizes and associates with the following block. This keeps the document visually clean – in reading view, the properties are invisible. In editing view, they appear as comments, clearly distinct from content. The parser knows to interpret these specific comments as metadata rather than as regular comments.
The advantage is minimal visual disruption. The document reads naturally; the metadata is present but unobtrusive. The disadvantage is discoverability – it’s less obvious that a block has properties when those properties are hidden. There’s also the risk of accidental deletion if someone removes what looks like a comment without realizing it carries structural information.
Visibility and interaction
Block properties should be visible in the editor but not intrusive. Two possible approaches:
Inline display with dimming. Properties appear in the editor, styled distinctly – grayed out, smaller font, different color – so they’re visible but clearly secondary to content. This keeps properties accessible without requiring extra interaction. Writers can see at a glance which blocks carry metadata and what that metadata says. The trade-off is visual density; documents with many block properties could feel cluttered.
Hover reveal. Properties are hidden by default. A small indicator – perhaps a subtle icon or a faint highlight – shows that a block has properties attached. Hovering over the indicator or the block itself reveals the properties in a tooltip or popover. This keeps the writing surface clean while maintaining access to the metadata. The trade-off is discoverability; properties don’t announce themselves, so they’re easy to forget about.
A setting could let users choose their preferred display mode. Different workflows might favor different approaches – dense technical documentation might benefit from visible properties, while long-form writing might prefer the cleaner hover-reveal interface.
Queryability as extension
The full value of block-level properties emerges when they’re queryable. This could integrate with Dataview or a similar tool, extending the query language to address blocks rather than just notes.
A query for deprecated sections across a documentation folder would return a list of blocks – not notes containing deprecated content, but the specific sections themselves. Each result would link directly to the block, using existing block-reference syntax. A table query could show all sections needing updates, with columns for version information, audience, and last-modified date – all at block granularity.
More sophisticated queries become possible once blocks carry properties. Find all flashback passages in a manuscript. Find all beginner-level sections across a tutorial series. Find all blocks linked to a specific source note. The vault becomes queryable at a finer grain than the note level.
This is a significant extension that would require coordination with Dataview or a new query system. It’s presented here as a logical evolution of the core proposal rather than a requirement for initial implementation. Even without queryability, block properties provide value for annotation and organization – but queryability is where the concept reaches its full potential.
Interaction with existing features
Block references. Block IDs already exist for creating references to specific blocks. Block properties would complement them – a block could have both an ID (for referencing) and properties (for metadata). The two features serve different purposes but could share syntax or infrastructure.
Inline fields. Dataview’s inline fields (field:: value) can appear anywhere in a note. But these fields aren’t block-scoped – they’re associated with the note as a whole, not with the specific paragraph they appear in. A query for notes with a certain inline field returns notes, not the blocks containing that field. Block properties would be explicitly scoped to their block, enabling queries that return blocks rather than notes.
Headings. Sections defined by headings are natural candidates for properties. A heading could implicitly define a block scope, with properties attached to the heading applying to the entire section until the next heading of equal or higher level. This would allow section-level metadata without requiring explicit block markers – the heading structure that already exists would serve as the block boundary.
Current workaround
Several partial workarounds exist, none satisfactory:
Splitting into multiple notes. Each section becomes its own note, with note-level properties. This fragments naturally unified content and creates navigation overhead. A documentation page that should be one coherent document becomes a folder of fragments. The cure is worse than the disease.
Inline fields in prose. Dataview’s field:: value syntax can appear anywhere in a note. But these fields aren’t block-scoped – they’re associated with the entire note, not the paragraph they appear in. Querying them returns notes, not blocks. The granularity problem remains unsolved.
Comments and conventions. Manual markers like %%TODO: update for v3%% or <!-- deprecated --> can annotate blocks. But these aren’t structured, aren’t queryable, and rely on human discipline to maintain consistency. They’re notes to self, not system-integrated metadata.
Tags on headings. Tags can appear after headings (## Installation #needs-update). This provides some block-level marking but is limited to headings, limited to tags (not key-value properties), and not queryable at the block level. It’s a partial solution that highlights the gap rather than filling it.
None of these approaches provide true block-level properties that are structured, queryable, and integrated into the editor experience.
Related feature requests
Proposed solution: yaml enclosed in curly braces after caret symbol.
E.g. ^{id: block-id, date created: 2020-11-06, authors: [he, me], inspired by: "Obsidian://vault/myvault/an%20idea"}
{#block-id, key = value, key = value}
In some existing formats (e.g. markua), metadata is located one line before multiline block (html div tag) or immediately after an “inline block”{#span-id} or after a # header {#heading-id} (extended markdown).
Initial caret symbol would indicate that it applies to the same scope as current Obsidian block-id syntax, not as in other formats.
It could extend to more lines with simple YAML notation and e.g. be optionally folded by default in editor.
If the YAML can be unambiguously recognized from “key = value” format, then both formats can be accepted or maybe even mixed, or extended to allow things like inclusion of unquoted wikilinks within yaml or “{#block-id}” which is syntactic sugar for “{id = block-id}” in some existing formats. So we could have e.g.
^{#block-id
	title: flexible format for block metadata
	authors: [ '[[he]]', me ]
	inspired by: '[[an idea]]'
	SRS: {last rep: 2020-10-13, mark: easy, next rep: 2021-08-06}
Future use cases
  • conversion between block-metadata and YAML-front-matter when refactoring notes from blocks to separate files and back
  • filtering blocks in search
  • displaying values in columns alongside text, like e.g. in “Notion” software or in Windows-File-Explorer.
  • tracking of provenance
  • conversion to graph database and analysis e.g. in Neo4j with Cypher
Keywords:
  • attributes, database, graph, metadata, properties
Related feature requests:
This is so cool. Obsidian has power of metadata and Obsidian will rule structural and unstructural–whole-- data.
Is there any thought for allowing arbitrary block boundaries? I’m think of being able to assign a single block-id to an arbitrary amount of content, including different elements (e.g., headers, paragraphs, lists, etc.).
Re: Comments:
Annotations are searchable using regex. Not palatable but it works for me. I do not annotate drafted, “in play” prose, but do so for ideas.
This works to nab all my highlights and comments for a particular prose piece:
((/==[^(==)]==?/) OR (/%%[^(%%)]%%?/)) “[[residency]]”
I like your posts today. Resonate completely.
Cheers!
An interesting aside triggered by dwelling on your words this morning:
I tend to draft in beats and ideas and they stay that way in my notes. It’s the closest thing to atomicity I do; for good reason.
I then use properties and links to bubble them up into future use. Like you, these “most favored and linked” notes get reused within different contexts.
In my sixth year and with each passing one the vault becomes more valuable and entertaining.
I too have been obsessed with the same or similar adjacent ideas and have looked into many solutions and alternatives. Here are some of my findings:
  • The Obsidian development team is very conservative about adding features, so they would probably not accept such a major change that could potentially slow down the entire Obsidian system.
  • That said, since block-level properties are completely optional, it seems like all that’s needed is to cache certain special symbols, as is already done with Markdown files.
  • In theory, it should be possible to simulate block-level property assignment by embedding a note and treating it like a block, but I have yet to see a feature or add-on that supports this.
    • Child note inheritance of parent properties, etc.
    • Seamless embedding and inline editing.
    • A method using base.
    • Something like an outline editor that can create properties for each indentation sounds interesting.
    • Existing note refactor and composer plugins only perform basic note-level processing from this perspective.
  • Kanban combines the appearance and functionality of text within a single note, but its semantics are weak and it does not allow for queries or complex tagging.
  • tasks plugin
    • An example of something that can be created inline, read based on specific tags, and add properties inline.
  • An example of an “Everything-node” type application.
    • Logseq
    • Anytype
      • Does not support block-level properties, but items can easily be changed to objects (i.e., notes or nodes).
    • Capacities
    • Tana
      • Hypertag feature: Tags nodes and enables node-level queries.
    • Siyuan
      • Properties can be assigned to blocks, but they are stored deep in the right-click menu and can only be easily visualized via a database.
  • Ease of writing and readability—that is, the appropriate and frictionless switching or integration of nodes (text) and properties—is important.
The only app in your list that is local and markdown only is Logsec and it uses the same “inline fields” that dataview uses. Interestingly, datacore does not.
The rest store their documents in a cloud database or have proprietary custom markdown for block level properties. Non of that makes for long term portability and accessability of my information.
Most of what is being requested in this post is used by a very small number of users.
I appreciate and solute the Obsidian developers for holding the line on maintaining a standardized markdown and local first strategy. Their not conservative, they are paying attention to what is possible and satisfies most users needs.
I achieve the equivalent of what is being requested with annotations, inline links, tasks, css styling and core search using regex. Bases is magical.
TBH, Obsidian isn’t all those other apps, for solid reasons. If the grass is greener elsewhere use those other toolsets.
Regarding the development team’s policy:
It’s a publicly known fact that the priorities of new features, including the number of people who want them, are vague when implementing feature requests. Additionally, we can infer the development team’s view of Obsidian’s core values ​​from other similar FRs. In this regard, I agree that you’re probably right that markdown=good in the context of adding this new feature. However, that doesn’t diminish the significance of this FR.
Regarding comparisons with other apps and the advantages of markdown:
I have no intention of making a common comparison about markdown=obsidian=good. The purpose of introducing other apps here is to point out that Obsidian’s system and workflow advantages are heavily dependent on markdown formatting, and to better define requirements by examining examples with equivalent functionality that can achieve the goals presented in the FR.
Regarding the use of annotations, inline links, tasks, CSS styling, and core search:
Do you mean queries that combine symbols that act as properties with block searches? Or do you mean a method of turning blocks into notes and assigning properties to them? I’d love to see a demo if you don’t mind. Using dataview/datacore is “theoretically possible” but difficult (at least for me), and doing anything beyond displaying search results is even more difficult. I also considered using obsidian’s embedded search, but all it would do is simply display the relevant blocks in the note, and I don’t think it would be able to do any of the organization or further processing shown in FR.
Related links:
Bases: Display, Access (and/or Filter using) the Note’s Content - Feature requests - Obsidian Forum
About the Feature requests category - Feature requests - Obsidian Forum
datacore/ROADMAP.md at master · blacksmithgu/datacore
I do alot of reading, annotation, and writing. For some subjects I make many annotation, specifically highlights and comments. Comments are my own words. Early on, six years ago, I also started assigning links to blocks where I had made comments. Sort of categorize my thoughts when I made comments.
Those annotations have become valuable and I find they get more valuable when I make new connections. Properties have enhanced the process.
About six months ago I started evaluating plugins that found annotatios but none of them provided me with value. So I started using regex in core search - I’ve left out a few curse words:). Extremely useful, but odd they are.
CawlinTeffid posted the following and it started me wondering what else I could do:
(/==[^(==)]*==( *(%%[^(%%)]+%%)|())?/) “[[residency]]”
It finds all notes with highlights, comments and a spicific link to a missive called “residency”. Since I place spaces after all blocks in notes, the results are offered up search results in nice fashion.
If I wanted to see where all three exist in each block, I enclose the above in a block:() command.
If I’m outlining an essay for example, I place links in selected blocks of research notes for things like [[title]] or [[beginning]] or [[backstory]] .
All of this can be done in a embedded search as well.
Depending on my need at any given time, I can tweak the search query and get results quickly. It would be nice to extract those blocks for use in canvas, for example, but core search does not, yet, do that. I bet it does at some point. For now, I can work with the core search sidebar and proceed to write missives and not have to hop around looking for stuff.
A recent plugin Always Color Text implemented a feature to colorize those individual elements of the search in a way that is really sweet. Highlights one color, comments another, and links. Each element has it’s own css definition.
Admittedly, my process may not appeal to others, but for me, as a research and drafting tool, I am in a happy place. It is quick, easy on the eyes.
Hope this answers your question.
I spent many years using Dataview, but just found I was spending way too much time doing dv than actually writing. It is powerful and, at some point, I’ll check out Datacore. Bases supplies my needs for statusing stuff.
Update: I built it as a plugin!
I’ve implemented this as the Block Properties plugin. It extends Obsidian’s block reference syntax to include metadata:
This is a paragraph with metadata. ^intro [status: draft, priority: high]
The plugin provides visual styling in the editor, a query command to search blocks by properties, and customizable display options.
You can find it on my GitHub!
Currently, Bases operates on a One Note = One Record paradigm. While this aligns perfectly with the atomic note philosophy, it creates significant friction for users who prefer to maintain centralized, flat logs (e.g., a single Movie Log.md with 100 movies listed, a Daily Journal.md with a bulleted list of daily tasks, or a Ledger.md of financial transactions).
Forcing these users to split a single, lightweight list into 100 separate Markdown files just to utilize the Table or Cards view adds unnecessary file bloat, complicates vault navigation, and breaks the user’s preferred data structure.
Introduce a new Source Type when creating or configuring a Base. In addition to “Folder” and “Tag,” add “File Blocks” or “Inline List.”
When a single file is selected as the source, the Base parser should treat individual Markdown elements within that file as the records.
Supported Inline Formats
  1. Bulleted / Task Lists with Inline Fields (Dataview-style)
    The Base parses each list item as a row, reading inline metadata formatting (e.g., [Key:: Value]).
  2. Standard Markdown Tables
    The Base natively hooks into an existing Markdown table inside a note, providing the advanced filtering, sorting, and Card layout UI on top of raw pipe-separated text.
  3. Frontmatter Arrays / Sub-properties
    Alternatively, the Base could parse a structured YAML/TOML array within the note’s single front matter block.
    Examples:
  • The Matrix [genre:: Sci-Fi] [rating:: 5] [watched:: 2026-05-10]
  • Inception [genre:: Sci-Fi] [rating:: 4] [watched:: 2026-06-01]
    OR
movies:
  • title: The Matrix
    genre: Sci-Fi
    rating: 5
  • title: Inception
    genre: Sci-Fi
    rating: 4
UI/UX Implementation Details
The Setup Flow: When creating a Base, selecting “Source: Single File” prompts the user to select the parsing method (e.g., “Parse bullet points,” “Parse Markdown table,” or “Parse YAML array”).
Two-Way Editing (Crucial): If a user edits a property inside a Card or Table view, the Base edits the specific string or block line inside that single file, maintaining Obsidian’s commitment to live two-way data syncing.
The “Card Layout” Render: For a movie list inside one file, selecting the Cards View would instantly turn those 100 bullet points into 100 visual tiles, rendering inline image links as cover art.
Related: Bases: Display, Access (and/or Filter using) the Note's Content
I slightly shortened the title (was “Please have bases support aggregation at block level rather than note level”).
Is this an actual plugin is or suggestion for improvement?
Not via a plugin. Suggestion for improvement.
Don’t have much to say other than this would be really useful. One file = one record is limiting and doesn’t work for some data.
To annotate blocks, I extend data-view properties but that allowing ‘anchoring’. It’s for notes that contain multiple entities. I use it to produce graphs, but it could be used by the native obsidian attributes as well
```markdown
People
Alice
age :: 25
Any text about Alice
Bob
age :: 27
Any text related to bob
knows :: Charlie
Charlie
surname :: Brown
It works as follows: each metadata variable is “anchored” to its H2 heading. In other words, any variables within a block are associated with the entity identified by that heading.
This requires the headings to be identifiable, but Markdown already supports this through document fragments, like Web pages. The approach works because Markdown has a tree-like structure, similar to HTML.
I’ve been using this for 4 years, without any problem.
In practice, I use both approaches: single-concept notes and multi-concept notes, which are usually lists. I use the YAML for metadata about the file (different to the content of the note)
In the past, I used arbitrary heading levels, but in practice I rarely need to go more than H3.
