Using mermaid diagrams in Obsidian is currently a bit clunky, and not everything works. Most of these issues can be addressed by allowing the users to resize and realign the mermaid diagram. I think this screenshot can demonstrate my points pretty well:
In theory, Mermaid supports customizing the size of the graph (and also the elements of the graphs) using “directives”.
Unfortunately, the doc presents conflicting syntaxes. Their examples don’t work in their own live editor.
Probably the devs haven’t finished implementing this yet. We will wait until this thing is sorted out and well documented upstream.
Some users have attempted modifying the look of the graph using CSS directly.
I would agree that it would definitely be nice to be able to resize. Finding a suggestion to use the following gave me hope, but I had no luck.
mermaid.flowchartConfig = {
width: 100%
Lately, when editing diagrams, I have just been using ctrl ± on Obsidian and using another editor to do the coding. It does make the process visually annoying and less convenient. Also, I tend to sometimes get various rendering artifacts when resizing or updating the code. It also means having to save every time I want the diagrams to update.
Anyways, I’m not sure what past solution you are talking about, but it gives me hope that resizing used to work. Going to check it out soon and potentially try to revert, although I am guessing it’s not possible to have multiple Obsidian instances installed.
As a side note, I am looking forward to some of the mermaid features in beta like the ability to define connections for subgraphs, the new connector shapes, and potentially eventually properly implemented nested subgraphs.
I just really feel like there is so much potential for plugins, hopefully core, that would let note connections be visualized and links be functional within diagrams. I know there are supposed workarounds but I haven’t succeeded with those either.
It’s good to see someone else excited about Mermaid in Obsidian, because I would definitely also be sad if things came to a permanent standstill.
I should add that I am extremely happy with all aspects of Obsidian development, and am mainly supporting mermaid as a continued direction regardless of what needs fixing.
To align all mermaid diagrams, you can write the following in your obsidian.css file (you can replace “center” with “left” or “right” if you choose to do so):
div.mermaid {
text-align: center;
Adjusting the width and height of mermaid diagrams is a bit trickier, but I found the following solution.
EDIT: While the solution below does technically work, please replace anywhere I’ve written svg[ig^="m"][width][height][viewBox] { *desired code* } in the css below with the much simpler .mermaid svg { *desired code* }. This simpler solution was offered by @smcllns in a later post on this thread.
The example below sets the width of the mermaid diagrams as 400px while preserving the aspect ratio:
I hope this helps! Also, for anyone interested, the steps I used to find this solution were the following:
I used Ctrl+Shift+I (on Windows) to open the obsidian developer tools while in preview mode. Then, I inspected the mermaid elements in my page and found that they have randomly generated id attributes all starting with the letter “m”. An example was the following:
<svg id="me4c26fffe5bb1328" ...>
N.B. The mermaid id attribute changes for an obsidian diagram after an obsidian site is published, so targeting a particular id using css and hoping for those changes to carry over is not feasible.
Through some searching online, I found that I can change the attributes of an html element whose name starts with a string by following the recipe:
In this case, the html element is svg, the attribute name is id, and the starting string is “m”, so I would have to write:
svg[id^="m"] { *desired code here* }
However, there may be other svg elements on a page that also have their id attribute start with “m”, so the above solution isn’t too specific.
In pursuit of greater specificity, I added [width], [height], and [viewBox] because each mermaid diagram I saw also had width, height, and viewBox attributes:
I’ve previously tried things inside <style></style> blocks as well, which didn’t end up working.
Instead, copy the CSS in a CSS file in the snippets folder of your obsidian vault, then go on the Appearance settings and activate said CSS file. Here are the steps:
Go to Settings > Appearance > Scroll down to CSS Snippets > Click on the folder icon on the right to Open snippets folder
Make a CSS file in the snippets folder with the desired CSS, then save the file (file must have extension “.css”)
Activate the CSS file snippet by toggling it on under “CSS Snippets” in the Appearance settings.
You used to also be able to write CSS in an obsidian.css file in the .obsidian folder, but I believe that feature is deprecated now, in favor of using CSS snippets instead.
Is there a way to set the aspect ratio of diagrams here? I’m making a Gantt chart, and in the Mermaid online editor, it is wide and shallow, e.g. 800 x 150 px. In Obsidian, it comes out much closer to square, e.g. 800 x 600 px. I’ve added a CSS snippet, and verified that setting height or width has an effect, but if I set them both, it keeps the aspect ratio the same.
Agreed with everyone here that the option to resize would be incredible. Also a big shout out to @Salamander23 for your snippets here.
Question - would it be possible to:
Create a setting under themes that enables users to force fit all mermaid diagrams into their notes? This could be made more sophisticated later if there is a strong preference for different kinds of behaviours depending on the type of diagram.
Add a mini menu when you hover over the rendered SVG with 2 options:
a. Download diagram as SVG
b. “Full size” this SVG - essentially popping it out into a resizable, floating window within Obsidian. The window would be centred on the starting node in the diagram by default. Having the diagram in a pop up window means that Obsidian could (in theory) render the SVG as a vector (zooming in / out as needed) without affecting the rest of the note. Users could then close the vector when they are done viewing it.
There may be better ways of doing it, but as I understand it, there appear to be two conflicting needs:
Ability to live-edit and fit diagrams within the regular flow of their notes no matter what size the diagram
Ability to view and read the diagram as and when needed, e.g. for sharing purposes
Enabling a 2nd layer of navigation for these objects (either via pop up / fixed size in line rendering engine) might go some way towards resolving the central conflict, as there is no way to control how large / wide a person’s Mermaid diagram might get.
@WhiteNoise leaving aside the Mermaid upstream issues with styling nodes, it seems like it would be helpful for everyone if Obsidian shipped with this css by default and didn’t require adding custom css:
