Don’t know if this belongs with one of the links below or is just the state of footnotes at the moment.
Open Sandbox
Paste the following into a note
footnote 1[^1]
footnote 2[^test]
footnote 3[^3]
[^1]: [help](https://help.obsidian.md)
[^test]: [docs](https://github.com/obsidianmd/obsidian-docs)
[^3]: a [main](https://obsidian.md/)
Footnotes 1~3 render as links.
Footnotes 1 & 2 don’t render as Markdown links. If any character is inserted between the : and the first [, the link becomes valid.
macOS 13.3.1, Obsidian 1.2.3 (1.1.16)
Debug info
Obsidian version: v1.2.3
Installer version: v1.1.16
Operating system: Darwin Kernel Version 22.4.0: Mon Mar 6 20:59:28 PST 2023; root:xnu-8796.101.5~3/RELEASE_ARM64_T6000 22.4.0
Catalyst license: supporter
Insider build toggle: on
Legacy editor: off
Plugins installed: 0
Plugins enabled: 0
Links work fine in Reading mode
Similar (but couldn’t find an exact match) →
https://forum.obsidian.md/t/first-link-in-footnotes-is-not-properly-recognized/3529
https://forum.obsidian.md/t/formatting-of-external-links-in-footnotes/29273
https://forum.obsidian.md/t/inline-footnotes-and-external-links/45260
https://forum.obsidian.md/t/backlink-in-inline-footnote-not-being-displayed-properly-in-live-preview-mode/41584/3
Using the dev tools, it doesn’t look like there’s a link at all after footnote 1 & 2.
Presume this is a live-preview issue—I have read posts about live preview not loading footnotes cleanly.
Your sample text creates three links (in my tests using 1.1.6) when viewed in reading mode. See the same with the insider build?
In Live Preview mode, add a footnote with a link immediately at the start.
It should look like a link.
It only shows source code, unless you add another character between the colon and the square brackets:
[image]
Source:
[^3]: [link](https://forum.obsidian.md/) not rendered as link
[^4]: a [link](https://forum.obsidian.md/) properly rendered as link
Both render fine in Reading mode.
Obsidian 0.14.0 (also 0.13.33) on mac…
Ha! That’s the post I knew had to be there.
Yeah, 1.2.3 is the same here. I know source/Live Preview doesn’t auto-render footnotes, but still odd behavior if someone types them in manually.
How did I miss that in your first post?
Sorry.
For anyone happy with a fudge:
A visual workaround is to use an invisible separator between the colon and the opening square bracket in the footnote.[^Oh]
Don’t know if it will copy in to forum.[^La]
But here goes.[^Ra]
[^Oh]: [help](https://help.obsidian.md)
[^La]: [docs](https://github.com/obsidianmd/obsidian-docs)
[^Ra]: [main](https://obsidian.md/)
invisible space source and reading
invisible space live preview and reading
ariehen
Closed
April 26, 2023, 9:37am
6
