the first word in the [[]] is not highlighted and Obsidian prompts me to add a new page for the second word, as it doesn’t exist.
Internal links in footnotes that work fine in preview mode are broken when I navigate to them in edit mode using Crtl + click. ONLY while in edit mode. If footnote includes multiple internal links, only the first link fails.
My system is a bit of a variant on the traditional Zettlekasten, so note names have a date/time stamp at the front, followed by a brief description or ID. All notes are in the same directory and file names have not been changed.
As you can see, in edit mode, the date/time stamp does not display as hyperlink. If I use Ctrl+click then Obsidian takes me to a new blank note using on the latter portions of the file name:
Edit mode:
However, in preview mode, the hyperlink displays and works correctly using the entire file name:
In edit mode, type a footnote
[^test]: [[this is a note]] -
The [[]] link highlight does not include the first word after the [[
Hovering over the [[]] link attempts to preview “is a note]]”
Fixed in 0.7. Let me know if it works for you!
No, this still doesn’t work. I’m on 0.7.3 - Mac OS insider build
Strange, I can reproduce now!
isso não funciona
The exact same bug.
Obsidian version: 0.7.4
OS: Windows 10
reporduce screen cast is attached.
bug.zip (673.4 KB)
Same bug, macOS Catalina 10.15.6, 0.8.15 latest installer.
Internal link and footnotes bug is still present in 0.9.6 (Installer 0.8.12) on macOS Catalina 10.15.7
will be fixed 0.9.13
