So, enter text multiple lines length without linebreaks;
Put cursor at middle of any of these lines.
Shift+home and Shift+end
Both should have same result with different half of line or whole text:
- “Home” should select from line start to cursor and “End” same with end of line
OR
- “Home” select from start of this text and “End” to end of this text
Mixed behavior. Home select to begin of line and End select to end of text
Win10x64 19043.985, Obsidian 0.12.10 in help vault.
I like suggestion in topic above. And would be good solution for Home also.
Press End once to go to the end of the soft wrap, press End again to go to the real end of the line. I think this could be a good solution for this as well.
