  1. Select a word in the middle of a sentence.
  2. Press Ctrl+B (to make it bold)
  3. Press Ctrl+Z to undo.
  4. BUG: the selection is no longer around the original word you selected, but is 2 positions/characters further down. You can continue steps 2+3 further.
  5. Press Home.
  6. Press Ctrl+B (to make it bold). 4 asterisks will appear with the cursor positioned after those four characters, instead of inside them. Btw. this is another bug that received no response so far: Pressing Home and ctrl+b/ctrl+i shortcut causes text to be inserted after asterix
  7. Press Ctrl+Z to undo.
  8. BUG: the selection is no longer at the beginning of the line, but is 4 positions/characters around the original word you selected, but is 2 positions further down. You can continue steps 2+3 further.
  • Operating system: Linux Mint 20.2 Cinnamon
  • Obsidian version: 0.12.10
Additional info:
Somewhat related topic:
It had a response. It was marked as reproduced.
You mean the “repro” tag?
From the forum newbie’s point of view:
  1. It’s small and hard to notice. It’s not as visible as for example a separate “I confirmed the bug and the developers were informed. Thank you!” message from moderators.
  2. It’s hard to know what it means and who added it.
  3. It is even harder to understand that that’s where the moderators would make any changes; that the bug reporter should look among the tags he filled in to see any new changes that should represent the change in bug report’s status. This is very non-trivial logic.
Thanks for the suggestion.
will be fixed in 0.12.13
