Obsidian Zettelkasten
121 - Unsurprising & Useful - this category of information typically is what you’ve already learned. Because you already know it, it is useless when presented to you again. Ideally you’d instead want to be presented with new information.
The one exception to this is periodic review. If you don’t use material or review it then the retrieval strength for a memory will eventually drop to where you forget information.
122 - Unsurprising & Useless Information - the worst type of information! This is the domain of cliches, whereby the phrase is unsurprising because its been overused and doesn’t help the situation at all because it is so generic.
123 - Compiling follows along the same lines as summarizing, whereby you are deciding what information is worth taking notes on in our infoglut society. This is an important skill to have because we have a limited amount of time on earth, so a certain amount of efficiency is necessary.
Zettelkasten Research
Blog Posts
126 - Effective Learning means integrating the right amount of information into your knowledge network in as quick a way as possible. It also means learning information in such a way that you won’t forget it when it is needed.
This means creating the pathways out of the right sets of information and connecting those pathways to retrieval cues. The more retrieval cues you connect the pathway to, the more likely it is you’ll remember it when needed.
What information to learn?
Our memory systems are built around utility, if you don’t end up using the information then the retrieval strength of it diminishes, eventually making it really hard to remember. Therefore in life, you want to learn the information that will have the most utility.
This does not mean only learning generalized information though. Often times specialized knowledge has a high amount of utility because there are not many others who have the specialized knowledge which forms the basis of specialized skills.
See Ranking of Knowledge
What is the right amount of information?
You want to find the right balance in the information you are selecting to learn. What does that mean?
Learning too much information would look like memorizing all the supporting details or problem examples. The reason you don’t want to memorize this information is because it is a little use in the wider context. Instead you want to extract the salient details and use them to build a mental model, which in turn can be used in unfamiliar problems.
On the other end is learning too little. If the information you are reading is too far abstracted from reality then it becomes meaningless. A word in a sentence becomes useless if you don’t already have the definition memorized.
See also Steps to Learning
127 - Tags are keywords/terms assigned to a piece of information to facilitate later retrieval. There are primarily two different type of tags I think about, keyword tags and thematic tags.
Keyword Tags - you can use tags to create a unique index. You do this by giving each note a tag specific enough that you will only ever have a couple notes per tag. When using tags in this manner, you do not want to tag every note. Instead you just want to create entry point into all the notes you have on a topic. An example of this would be creating a #cognitive-skills tag that leads to this note, which is the start of a sequence of notes on cognitive skills.
Thematic Tags are how tagging is typically done. Often a note will be the intersection of multiple ideas, especially when you are remixing information. For example, my note sequence on the future of work would have both the tags #future and #work. Then when I go to search I type in multiple tags to find if I have notes on the intersection of different topics I write about. It can be especially useful with large note collections if you create a heat map out of them and see if any themes emerge that you didn’t know about.
128 - Multi Tags Plugin - allow for different type of tags, whereby there are two tags pane. This allows for the creation of both Keyword & Thematic Tags.
Not sure how this would be technically implemented, but from a design standpoint you could easily distinguish between the two types of tags using color.
129 - Links - are pointers that allow for easy navigation between related notes. Internal Links are connections between notes within the program. For Obsidian these take the form of tags (link to a custom selection of notes), index (File Explorer), and links to other notes within the note itself. External Links are connections between a note and either an external program, most commonly a web page.
You can think of links as serving both a specific and general purpose. The specific purpose is to point you towards a set of information you are looking for. This is what the file explorer and search function are for. The general purpose of links is to inform you of related information to what you are searching for. If you think about the information suprisal factor of a link, then the best ones are those that point you towards additional information that you were unaware of.
The additional information can either be specific or contextual. A contextual link can point you towards the wider context of information. A note about my father sits in the wider context of his social relationships (family, work, community, etc). A helpful contextual link would point you towards the wider context of a note that you didn’t know about. A specific link would be linking to another related concept, such that you fabricate serendipity between notes.
Related Connections & Quality of Connections
130 - Quality of Connections - Every note you create will be full of terminology. Each term is a connection you can create in a note. Then you can also put in connections to related concepts that aren’t directly mentioned in the note, which you’ll see when I put a “See” or “Related” at the end of the note.
This led me to think about what is the right balance with linking? I imagine that heavily linking my notes, such that every sentence has multiple links, is not only distracting but a waste of time. You want to strike a balance, such that you are only linking the most useful information. You can think about it through the utility & suprisal framework.
High Quality Connections would therefore be ones that are useful, even if they aren’t surprising. A perfect link would be one that would provide you with new information that you can use. A less than ideal link (but still good) would be one that provides you with useful information but you pretty much already know. This leads to the question of “what makes a link useful?”.
Low Quality Connections would be connections that have little utility, whether they be surprising or not. What would be an example of both? #todo
131 - Design of Perfect Zettelkasten App - what would be the features of my ideal zettelkasten application? One way to approach this question is to think about what software features facilitate knowledge management and knowledge development.
  1. What information can you include in the storage process that will make note retrieval easier?
  2. What information can you include in the storage process that will facilitate knowledge development?
  3. How can you sort your notes to make information retrieval easier?
  4. How can you sort your notes to facilitate knowledge development?
  5. What can you do to the search or selection process to make sure you are retrieving all the relevant information?
  6. How can information summarizing be integrated and useful in a zettelkasten system?
  7. What does curation look like in a zettelkasten system?
The primary question around storing information in a zettelkasten app is what structures and meta data will best facilitate retrieval of the information at a later date, which involves the sorting and selecting processes. The other important question is what meta data or formatting structure can you include to help facilitate knowledge development?
There are five components to the storage format: note title, note headers, note body, note tags, and note links. Note titles allow you to link to the note either through the program itself (file explorer, note search) or in the body of the note (e.g. hyperlinks). You can also include secondary functions through titles such as having a Time ID that gives you context for a specific period of your life or unique names that give you a quick idea of what the notes are about.
Other Features
Placeholder Text
Related - Layers of Structure
#to-do
Ideal Note Format
131 - Textbook Deconstruction - start out by asking yourself why you are reading the textbook? This will dictate what the best approach to taking notes on it will be.
  1. Required for your primary field of study? (e.g. Introduction to Psychology textbook for student planning on becoming a Psychologist, see specialized knowledge)
  2. Part of your learning for general knowledge? (e.g. Economics Textbook for a course that you have to take but isn’t part of your core knowledge base)
Components of a textbook you can take notes on: key terms, concepts, models, and their relationships. For introductory textbooks, you can often think of the table of contents as a representation of a basic model of the field. What can you do with these components?
#rework #to-do
132 - Foundational Notes are the notes you make to create an initial layer of structure that further notes will be tied to. They are created to help facilitate knowledge development.
They can take the form of basic knowledge (e.g. term’s definition) or structural knowledge (e.g. book’s table of contents). Sometimes those are combined, as is the case with my future roles note, which lays out all the different future roles and provides defenitions for each.
When thinking about basic knowledge, it can be well established and already defined information (e.g. cognition note) or new terminology (e.g. evergreen notes).
Notes on structural knowledge are for mapping out an idea, in which you think you’ll forget the map. I will often do this with the use of bullet point lists at the end of notes. An example of this would be Note 111, pictured below.
I will often put a #todo at the end of it as a reminder to come back and create notes around the different parts of the map/outline.
133 - Simple Zettelkasten Guide - this post over on Zettelkasten De forum made me realize I should probably work on creating a very simple zettelkasten guide.
Once I’ve filled out all the notes listed below, then I will combine them all in the forum post.
Outline
Creation of a more Elaborate Zettelkasten Guide being outlined here
134 - Simple vs. Simplistic - you want to aim for simple understanding, explanations, and solutions, while avoiding simplistic ones.
ThoughtCo offers a good explanation of the difference between the two. The importance of knowing the difference between the two was brought to my attention from reading Feynman’s books. Not sure which book he talks about it in, but here is a blog post that sums up his views.
This is what underlies the Feynman Learning Technique.
135 - Information Approach Quadrant
  1. Take notes on core concepts, models, and relationships + memorize them.
  2. DO NOT take notes on them + memorize them
  3. Take notes on core concepts, models, and relationships + DO NOT memorize them
  4. DO NOT take notes on core concepts, models, and relationships + DO NOT memorize them
Option 1: you want to do this if you think you’ll be further developing those topics, while also needing to memorize them for test
Option 2: you don’t think you’ll be further developing them but need to memorize them for the test. You usually do this for concepts that you think you’ll be using so much that you don’t need notes on them because you’ll always have them memorized until you die. The most basic example of this is the words in this sentence. You don’t have a note for every word that I’m using right now because you have it memorized forever.
Option 3: Information that you find interesting or believe to be important but won’t be tested on, so no need to memorize. These might be concepts you think will want to expand upon or use to develop other concepts in the future. These are often notes you take while reading common nonfiction books.
Option 4: These are concepts you don’t plan on developing or already have memorized. You don’t copy and paste every word in a book or memorize the entire book. Often this is the irrelevant details used in a book to help you understand a concept (e.g. examples and supporting details).
#todo REFINE AND MS PAINT DIAGRAM
136 - Evolution of Note Taking
Note Taking at its core is the storage of information. This information started out in the form of knowledge (memorized information) that aided us in survival as a species, such as the location of the watering hole and what time of day animals congregate there.
Over time as survival became easier, we have been given the space that allows for the collection of information that isn’t vital to living. The explosion of information ran into conflict with our brains desire to streamline information for survival purposes (forgetting). So we started to write down information that we didn’t want to forget and referenced it when necessary.
This also allowed us to share information with each other over time and space, leading to an even greater proliferation of information. Over the centuries you see the cycle of information explosion and creation of tools to manage it, such as the index and table of contents.
137 - Brief Mapping of Core Note Taking Functions
For most of time the tools have been centered around the core four note functions involved in referencing: storage, sorting, selecting, summarizing (Blair 2010, pg 15). Lets take a look at it from a paper and digital viewpoint, starting with a paper reference book.
  1. You start by storing the information on paper of various sizes and qualities.
  2. You then create pointers to the different sections of information so that you can easily find them again. Two common ways of sorting the pointers are thematic and alphabetical.
  3. The reader would then select the information they want to reference using the sorted pointers. If you wanted to search for the information thematically, you’d use a table of contents. Alphabetically, you’d use an index.
  4. Because the information out there is too big for one book, the authors of reference books would include summaries of other information collections (other books).
The digital version of this would be Wikis such as Wikipedia or SuperMemoGuru.
  1. You store the information on a latticework of webpages, with each page explaining an idea or concept.
  2. The information is sorted through unique page names, which in turn can be searched, removing the need for advanced sorting techniques. On both mentioned websites, pages are often sorted thematically for easier comprehension with the use of hubs or table of contents.
  3. To select the information you can either use links or a universal search.
  4. Wikipedia implements summarizing through the creation of page introductions/overviews at the top of each page.
138 - Zettelkasten is about Development
Zettelkasten, “note box” in German, is a broad term that can represent a different set of ideas depending on who you talk to. For the purpose of this guide, I am using it to reference both the note taking system of sociologist Niklas Luhmann and my digital interpretation of it.
The zettelkasten system is about introducing a fifth function, that of development. Instead of just structuring material for future reference (e.g. book or wiki), you are structuring it in a way that helps you further develop your knowledge base . Once a section of your knowledge base (zettelkasten) has been sufficiently developed, you can then use it in a couple of ways.
  1. You can share the knowledge you developed through a research paper, blog post, or book.
  2. You can formalize the knowledge into a more useful form that can then be referenced later. This would be using your zettelkasten to create an entry in your personal wiki.
  3. Leave the notes alone and just reference them next time you run into a situation where that set of information would be helpful.
  4. You can formalize the knowledge into a model that you memorize. This would be akin to creating a sequence of notes about a cooking recipe that you are experimenting with. After you’ve created a sequence of notes on the recipe over a span of 3 years, you memorize the ideal recipe intentionally with a program like Anki or unintentionally by just using the recipe frequently.
139 - Developing Knowledge - what are the different ways we develop knowledge?
You can further developing your knowledge base in multiple ways. The two primary forms it takes is the generation of new ideas and the creation of structure.
As you create individual notes and link them together, you are creating a structure. Structure can take the form of mapping out the most important components of a idea. If I were to model/map out “my family”, I would include notes on all the members and the interpersonal dynamics between us. Another form of structure is the creation of arguments and the corresponding evidence, including counter evidence. For example, I have a sequence of notes about how awesome dogs are. Every time I come across new information that supports or detracts from this argument, I add it to the note sequence.
  • New Ideas
  • Remixing Ideas
  • Representing Ideas
  • Creating New Connections
  • Pooling Diverse Sources (Spatial)
  • Pooling Information over Time (Temporal)
140 - Features of a Physical Zettelkasten
Reference Features of a Physical Zettelkasten
  • How Luhmann Structured his Notes for Increased Development
  • Note Titles
  • Index
Developmental Features of a Physical Zettelkasten
  • Luhmann IDs
  • Note Sequences
  • Linking between Notes
