When I look for things in my vault to link them to the note I am currently in, I find it useful to be able to drag and drop relevant links directly into the note. Currently, this only works for note level links. Since you can also search for sections in search results, which offers very granular search results, it would be great to be able to drag and drop these results as header or block links directly into the current note.
When dragging and dropping a header or block, you get a link to this heading or block respectively, instead of a link to the note they reside in.
Get link to note and then filter that link or type in [[##]] or [[^^]] to find the block or heading directly
Run a Copy Block Link command to save link to block or block embed.
Paste in note.
But the feature requested here would come in handy, and would save a few clicks
The drag & drop functionality in Obsidian feels notably limited. Several intuitive use cases where drag & drop would be a natural interaction pattern are currently unsupported. A few notable examples:
