DataviewJS Snippet Showcase
I’m trying to build the DataviewJS query. That is extracting the vault path and building the full path for image by combining YAML Header where I have only name of the image with extension as string
YAML Header
number: 1
image: "image12.jpg"
sphere: Earth
DataviewJS query
dataviewjs
//@ts-ignore
let adapter = app.vault.adapter;
 // VAULT PATH
const vault = adapter.getBasePath();
 // PATH WHERE I HAVE IMAGES
const vault_images = vault + "/Resources/Images/"
const pages =
		dv.pages()
		.where(b => b.file.frontmatter.sphere === 'Earth')
		.sort(b => b.file.frontmatter.number)
		.array()
	.map(({file}) => {
 // PROBLEMATIC LINE
	return ["![](" + vault_images + file.frontmatter.image + ")",file.name, file.frontmatter.number]
dv.table(["Image", "Name", "Number"], pages)
Result
It gives me the table of all items, but there is just one image propery for all records. It looks like it is giving me all images as object.
I will really appreciate somebody who can help me to adjust the code :folded_hands:t2:
Love it
SHOW IMAGE BASED ON YAML PARAMETER
IMAGE FILE: base_color.jpg
Note
date:
image: color
tags:
dataviewjs
const prefix = "base"      /// image prefix
const ext = ".jpg"         /// image extension
const size = "200"         /// image size
const cover = "![[" + prefix + "_" + dv.current().image + ext + "|" + size + "]]"
dv.paragraph(cover)
I am using $=dv.pages().length in a vault info bar to show the total number of files in the vault but I want to also have a inline snipped that shows the number of files modified today, what code would I use?
  • You could use the following Inline DataviewJS Query.
### inDVJS10
QTY_modified_today=`$=dv
    .pages()
    .where((page) => page.file.mday.toFormat("yyyy-MM-dd") === dv.func.date("today").toFormat("yyyy-MM-dd")).length;`
Topic
Summary
  • How to filter the data by the filename of a link from the Markdown files with the case_YAML_Y-YYY structure?
Structures: case_YAML_Y-YYY
Summary
TIP:
1.AoH in the topic means an Array of Hashes.
2.Hashes in the topic means JavaScript Objects.
Definitions:
Structure Code: case_YAML_Y-YYY
Definitions: Use nested YAML fields, where a single root YAML field which is an Array of Hashes consists of
at least one Hash, which is represented by sub YAML fields “-YYY”.
YAML: Use YAML.
Y: a single root YAML field which is an Array of Hashes
-YYY: at least one Hash, which is represented by sub YAML fields “-YYY”
The first sub YYY, an element of the root Y, consists of multiple key/value pairs, as known as a Hash.
The second sub YYY, an element of the root Y, consists of multiple key/value pairs, as known as a Hash.
Data Structure: an AoH
Original Structure Code expressed in regular expressions: case_YAML_Y(-YYY){1,}
Basic Example: The AoH drinks consists of two elements with the data type of a Hash.
NOTE:
Take the following file db_20220110 as an example.
Y: drinks, which is an AoH
-YYY: The first sub YYY, an element of the root Y, contains multiple key/value pairs, as known as a Hash.
-YYY: The second sub YYY, an element of the root Y, contains multiple key/value pairs, as known as a Hash.
```yaml
Date: 2022-01-10
drinks:
  # The first sub YYY
  - item_name: "Black Coffee"
    unit_price: 120
    caffeine_content: 300
    item_no: "IT001"
  # The second sub YYY
  - item_name: "Green Tea"
    unit_price: 100
    caffeine_content: 200
    item_no: "IT002"
Basic Example: The AoH drinks consists of one element with the data type of a Hash.
NOTE:
Take the following file db_20220111 as an example.
```yaml
Date: 2022-01-11
drinks:
  # The first sub YYY
  - item_name: "Apple Juice"
    unit_price: 110
    caffeine_content: 0
    item_no: "IT003"
Notes:
Summary
Q1: What is the data structure of the file dic_19920301?
Summary_Q1
Original Example: Q1 (To be explained)
NOTE:
Take the following file dic_19920301 as an example.
```yaml
date: 1992-03-01
purchases:
  - store: "[[some store]]"
    item: some item
    comments: comments
  - store: "[[another store]]"
    item: another item
    comments: other comments
A1:
Another Example: A1_11 (Before using FLATTEN)
NOTE:
Before running FLATTEN purchases AS OnePurchase, the field purchases in the page, is an AoH as shown below.
  • Here is a slice of the page hash, where the page.file.name is dic_19920301.
```JSON
    date: "1992-03-01T00:00:00.000Z",
    purchases: [
            store: "[[some store]]",
            item: "some item",
            comments: "comments",
            store: "[[another store]]",
            item: "another item",
            comments: "other comments",
Another Example: A1_12 (After using FLATTEN)
NOTE:
After running FLATTEN purchases AS OnePurchase, the OnePurchase in the page is a Hash as shown below.
```JSON
        OnePurchase: {
            item: "some item",
        purchases: [
                item: "some item",
        OnePurchase: {
        purchases: [
                item: "some item",
Q2: What is the data structure of the file dic_19920601?
Summary_Q2
Original Example: Q2 (To be explained)
NOTE:
  1. Take the following file dic_19920601 as an example.
  2. The purchases in the page is a Hash.
```yaml
date: 1992-06-01
purchases:
    item: some item
    comments: comments
A2_21:
Another Example: A2_21
  • Here is a slice of the page hash, where the page.file.name is dic_19920601.
```JSON
    date: "1992-06-01T00:00:00.000Z",
    purchases: [
            item: "some item",
Test
Summary
  • dataview: v0.5.55
Input
Summary
dictionary files: for the DQL10
  • Location: “100_Project/02_dataview/Q17_Purchases/Q17_test_data”
folder: 03_an_AoH_consists_of_two_hashes
  • filename : dic_19920301
date: 1992-03-01
purchases:
    item: some item
    comments: comments
    item: another item
folder: 04
  • filename : dic_19920401
date: 1992-04-01
purchases:
    item: apples
    comments:
    item: oranges
    comments:
folder: 05
  • filename : dic_19920501
date: 1992-05-01
purchases:
    item: potatoes, potatoes
    comments:
    item: a very big watermelon
    comments:
folder: 06_an_AoH_consists_of_one_hash
  • filename : dic_19920601
date: 1992-06-01
purchases:
    item: some item
    comments: comments
folder: 07_an_AoH_contains_one_empty_hash
  • filename : dic_19920701
date: 1992-07-01
purchases:
    item: some item
    comments: comments
  - store:
    item:
    comments:
folder: 08_null
  • filename : dic_19920801
date: 1992-08-01
purchases:
  - store:
    item:
    comments:
  • filename : dic_19920806
date: 1992-08-06
purchases:
folder: 09_undefined
  • filename : dic_19920901
date: 1992-09-01
folder: 10_excluding_store_not_link
  • filename : dic_19921001
date: 1992-10-01
purchases:
  - store: "another store"
    item: another item
    comments: comments
DQL10_filter_by_filename_of_a_link_and_TABLE: case_YAML_Y-YYY
Summary
Main DQL
Code Name Data type Group By Purposes Remark
DQL10
_filter_by_filename
_of_a_link
_and_TABLE
OnePurchase.store:
a link
no 1.To filter by purchases
2.To split up a list purchases into each individual element OnePurchase
3.To filter by OnePurchase and OnePurchase.store
4.To define a field variable s_filename_of_link
5.To filter by s_filename_of_link
6.To sort by date in descending order
7.To display the result as a table
NOTE:
Require the files with the case_YAML_Y-YYY structure
The Regular Expression in the DQL10 is based on the DQL10 in the following topic.
- Solutions: by Justdoitcc
Code DQL10_filter_by_filename_of_a_link_and_TABLE: case_YAML_Y-YYY
Summary_code
title: DQL10_filter_by_filename_of_a_link_and_TABLE =>0.Require the files with the `case_YAML_Y-YYY` structure 1.To filter by `purchases` 2.To split up a list `purchases` into each individual element `OnePurchase` 3.To filter by `OnePurchase` and `OnePurchase.store` 4.To define a field variable `s_filename_of_link` 5.To filter by `s_filename_of_link` 6.To sort by `date` in descending order 7.To display the result as a table
collapse: close
icon:
color:
```dataview
TABLE WITHOUT ID
      file.link AS "File",
	    OnePurchase.store AS "store",
	    OnePurchase.item AS "item",
	    OnePurchase.comments AS "comments",
      s_filename_of_link AS "filename_of_store"
FROM "100_Project/02_dataview/Q17_Purchases/Q17_test_data"
WHERE purchases
WHERE OnePurchase AND OnePurchase.store
FLATTEN regexreplace(meta(OnePurchase.store).path, "^(.*/)(.+)(\.md)$", "$2") AS s_filename_of_link
WHERE contains(s_filename_of_link, "another store")
SORT date DESC
Screenshots(DQL10)
Reference
Summary
Q88_Links:Regular Expressions
```dataview
FLATTEN regexreplace(meta(up).path, "^(.*/)(.+)(\.md)$", "$2") AS s_filename_of_link
YAML to JSON converters
YAML Formatters
Oh! I didn’t know this is possible!
That’s why I developed my plugin “Table to CSV Exporter”. :wink:
I just started using Obsidian a few days ago as a daily journal and finally got my first dataviewjs query working this morning!
It’s nothing too fancy, especially compared to the query in the OP of this thread, but I just wanted to share my little success. My query creates a table of people mentioned in my daily notes, sorted by most recent mention, a count of mentions, and shows me their relationship to me (friend, family, work).
The thing that made this a bit complicated to setup (for me as a newbie) was that I wanted it be completely automatic and not require any manual editing of YAML. I initially had a field in each person’s note that I would have had to update with the date of our last meetup, but instead I found a way to get the latest daily note and use that as the date.
I also originally had a field for relationship, but since I already had everything set up in folders I figured that there might be a way to inherit that directly from the folder structure, and there was.
So here is what the end result looks like…
In my fault I have a folder called “People” and sub-folders in it that have an individual note for every person like this:
And my query gives me this table:
// Get the latest daily note mentioning this person. Daily notes must be named so that most recent is latest alphabetically.
function latestDailyNote(k) {
	let notes = k.file.inlinks;
	notes = notes.map(n => dv.page(n));
	notes = notes.where(n => n.file.folder == "Daily Journal");
	notes = notes.map(n => n.file.name);
	notes = notes.sort(n => n,'desc');
	return notes[0];
dv.table(["Name", "Relationship", "Mentions", "Last Mention"], dv.pages('"People"')
	.where(p => !p.file.link.equals(dv.current().file.link)) // Must use equals(), == fails because not both strings?
	.sort(p => latestDailyNote(p), 'desc')
    .map(p => [
	    p.file.link,
	    p.file.folder.split("/")[p.file.folder.split("/").length-1],
	    p.file.inlinks.length,
	    latestDailyNote(p)]))
I’ve probably written this in an unnecessarily convoluted way as I have zero experience in javascript. I’m just happy that the thing actually works, but would welcome any improvements, especially ones that might make it more efficient.
One thing that caused me a lot of problems in particular was working with links. It seems that links don’t necessary sort by the text of the link. Does anyone know how an array of links is sorted? In the end I settled for using dv.page to get the page of the link and then file.name to get the text of the link and sorting on that.
I’m trying to do a dv.table without the counts in the headers.
Anyone has an idea how to do so? I’m seeing
https://github.com/blacksmithgu/obsidian-dataview/search?q=values.length
and it appears there is no configuration option. At the same time, I see many people posting screenshots of examples where there are no counters in the headers.
See here:
Generated like this:
title: Meetings
days: -10
# Upcoming Meetings
```dataviewjs
Date.prototype.addDays = function(days) {
    var date = new Date(this.valueOf());
    date.setDate(date.getDate() + days);
    return date;
function sortDate(a, b) {
	return new Date(a) < new Date(b);
function padTo2Digits(num) {
  return num.toString().padStart(2, '0');
function formatDate(date) {
	date.setHours(0, 0, 0, 0);
  return [
    date.getFullYear(),
    padTo2Digits(date.getMonth() + 1),
    padTo2Digits(date.getDate()),
  ].join('-');
let pg = dv.current();
let pages = dv.pages("#meeting")
	.where(p =>
		   p.date
		&& p.file.name != pg.file.name
		&& new Date().addDays(pg.days) <= new Date(p.date)
	.sort(p => p.date, "desc", sortDate)
for (let group of pages.groupBy(
			b => formatDate(new Date(b.date))
	dv.table(
		  [group.key, "Meeting"],
			group.rows
			  .map(k => [ k.date, k.file.link ]
I’m sure this is stupidly easy question but I’m a javascript novice and I’ve been working an (unrelated) update all night. Googling skills haven’t helped, so can someone assist?
I have an inline dataviewjs script and all I want to do is a case-insensitive string compare. In straight dataview I’ve been doing this: WHERE contains(lower(muddle),“blarg”)
where ‘muddle’ is defined in YAML.
In my inline dataviewjs script I have .where( k => k.muddle == “blarg”) which works as long as the case fully matches but I haven’t been able to force ‘k.muddle’ to lowercase. toLowerCase, lower, etc. have been tried as a result of google searches.
Trying to get some magic with Dashboard++…
Help? Thanks!
Topic
Summary
  • How to hide the file count in the_nth_of_table dataview table?
  • How to hide the file count in each dataview table?
Using DVJS
Summary_DVJS
Hide the file count in the the_nth_of_table dataview table
```JS
// M91. hide the file count in the `the_nth_of_table` dataview table :
let the_nth_of_table = 2;
this.container.querySelectorAll(
    ".table-view-table tr:first-of-type th:first-of-type > span.small-text"
)[the_nth_of_table - 1].style.visibility = "hidden";
Hide the file count in each dataview table
```JS
// M99. hide the file count in each dataview table :
let css_Lists = this.container.querySelectorAll(
for (let i = 0; i < css_Lists.length; i++) {
    css_Lists[i].style.visibility = "hidden";
Using CSS snippet
Summary_CSS
```CSS
// C99. hide the file count in each dataview table :
.dataview.small-text {
  display: none;
Reference
Summary
Topic
Summary
  • How to use dv.func.contains in a case-sensitive string comparison?
  • How to use dv.func.icontains in a case-insensitive string comparison?
Test
Summary
  • dataview: v0.5.46
Input
Summary
dictionary files:
  • Location: “100_Project/01_dataviewjs/01_by_example/Q84_Contains/Q84_test_data”
folder: 03
  • filename : dic_19850301
Date: 1985-03-01
muddle: BLARG123 abc
folder: 04
  • filename : dic_19850401
Date: 1985-04-01
muddle: BLARG abc
folder: 05
  • filename : dic_19850501
Date: 1985-05-01
muddle: blarg456 abc
folder: 06
  • filename : dic_19850601
Date: 1985-06-01
muddle: blarg abc
DVJS10_icontains_and_TABLE
Summary
Main DVJS
DVJS10_icontains_and_TABLE muddle:
a string
no 1.To filter by muddle(An existence check)
2.To filter by muddle(case-insensitive)
3.To display the result as a table
Notes
Summary
The same codes:
  • To filter by muddle(case-insensitive)
Original Example10: DVJS
```JS
.where((page) => dv.func.contains(page.muddle.toLowerCase(), "blarg"))
Another Example11: DVJS
```JS
.where((page) => dv.func.contains(dv.func.lower(page.muddle), "blarg"))
Another Example12: DVJS
```JS
.where((page) => dv.func.icontains(page.muddle, "blarg"))
Another Example21: DQL
```SQL
WHERE contains(lower(muddle), "blarg")
Another Example22: DQL
```SQL
WHERE icontains(muddle, "blarg")
Code DVJS10_icontains_and_TABLE
Summary_code
title: DVJS10_icontains_and_TABLE =>1.To filter by muddle(An existence check) 2.To filter by muddle(case-insensitive) 3.To display the result as a table
collapse: close
icon:
color:
```dataviewjs
// M11. define pages: gather relevant pages
let pages = dv
    .pages(
        '"100_Project/01_dataviewjs/01_by_example/Q84_Contains/Q84_test_data"'
    .where((page) => page.muddle)
    .where((page) => dv.func.contains(page.muddle.toLowerCase(), "blarg"));
    //.sort((page) => page.file.name, "desc");
// M31.Output :
//dv.header(2, "pp"); //org
dv.table(
    ["File", "muddle"],
    pages.map((page) => [page.file.link, page.muddle])
Screenshots(DVJS10):
Thanks! That solved it. I can see I’m going to need a JavaScript course. Most of my coding was 10+ years ago and in C, C++ or Perl 5. Rust, so much rust…
I modified your countdown method, adding a dateDiff method using Mordred’s answer from this stackoverflow question. Now the table shows that their birthday date is 1 month(s) 20 Day(s) away.
var start = moment().startOf('day');
var end = moment(start).add(dv.current().duration);
var dateformat = "YYYY-MM-DD";
if (dv.current().dateformat) { dateformat = dv.current().dateformat; }
// info text above table, {0}=duration, {1}=start date, {2}=end date
// parameters can be left out, or the string empty
var infotext = "Upcoming birthdays for {0} from now ({1} – {2})<br><br>";
function nextBirthday(birthday) {
    // Get person’s next birthday on or after "start"
    // returns a moment
    // need to "unparse" because DV has already converted YAML birthday to DateTime object
    // shouldn’t harm if already a string
    var bday = moment(birthday.toString());
    var bdayNext = moment(bday).year(start.year());
    if (bdayNext.isBefore(start, 'day')) {
        bdayNext.add(1, "year");
    return bdayNext;
function turns(birthday) {
    // Get the age in years a person will turn to on their next birthday
    return nextBirthday(birthday).diff(bday, 'years');
function dateDiff(startingDate, endingDate) {
	let startDate = new Date(new Date(startingDate).toISOString().substr(0, 10));
	if (!endingDate) {
		endingDate = new Date().toISOString().substr(0, 10); // need date in YYYY-MM-DD format
	let endDate = new Date(endingDate);
	if (startDate > endDate) {
		const swap = startDate;
		startDate = endDate;
	    endDate = swap;
	const startYear = startDate.getFullYear();
	const february = (startYear % 4 === 0 && startYear % 100 !== 0) || startYear % 400 === 0 ? 29 : 28;
	const daysInMonth = [31, february, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31];
	let yearDiff = endDate.getFullYear() - startYear;
	let monthDiff = endDate.getMonth() - startDate.getMonth();
	if (monthDiff < 0) {
		yearDiff--;
		monthDiff += 12;
	let dayDiff = endDate.getDate() - startDate.getDate();
	if (dayDiff < 0) {
		if (monthDiff > 0) {
			monthDiff--;
		} else {
			yearDiff--;
			monthDiff = 11;
		dayDiff += daysInMonth[startDate.getMonth()];
	return monthDiff + ' Month(s) ' + dayDiff + ' Day(s) away';
function countdown(birthday){
	const setTime = new Date(bday);
	const nowTime = new Date();
	const dateDifference = dateDiff(nowTime, setTime);
	return dateDifference;
function showBirthday(birthday) {
    // Determine if this birthday is in the range to be shown
    // including the start date, excluding the end date
    // because that comes from a duration calculation
    // for use with "where", returns true or false
    if (birthday) {
        var bdayNext = nextBirthday(birthday);
        if (bdayNext.isBetween(start, end, 'day', '[)')) {
            return true;
        } else {
            return false;
    } else {
        return false;
function sortByNextBirthday(a, b) {
    // comparator function for "sort"
  if (nextBirthday(a).isBefore(nextBirthday(b))) {
    return -1;
  if (nextBirthday(a).isAfter(nextBirthday(b))) {
    return 1;
  // they’re equal
  return 0;
dv.paragraph(infotext.format(moment.duration(dv.current().duration.toString()).humanize(), start.format(dateformat), end.format(dateformat)));
dv.table(
    ["Name", "Birthday", "Turns", "Countdown"],
    dv.pages(dv.current().searchterm)
        // use a function to see if this birthday is in range to be shown
        .where(p => showBirthday(p.birthday))
        // use a comparator function to sort by next birthday
        .sort(p => p.birthday, 'asc', sortByNextBirthday)
        .map(p => [
            p.file.link,
            p.birthday ? nextBirthday(p.birthday).format(dateformat) : '–',
            turns(p.birthday),
			countdown(nextBirthday(p.birthday)),
Hey, thanks for a great JS code. I tried to make it work but i didnt succed.
I put these in the front matter:
birthday: 2000-01-01
#searchterm: "#family or #friends"
searchterm: '"People"'
duration: 1 year
And added the code in another note as a plain text, unfortunate i just see the code but it doesnt run, what did i do wrong?
Thanks.
Hello all, I’m sure this is probably very easy, but I’m a bit new to dataview.
I would like to use dataview to build a table (not a dataview TASK view) that includes a column with the note name and link (the first column) and a column with the text of the first uncomplete task that appears on that page. I’ve been trying all day to figure this out and nothing I do seems to come even close.
Many thanks in advance!
Last july, @Moonbase59 , created a script to list the current hotkeys, and I got news of this today. I discovered that if multiple keys was defined, it didn’t show the alternate keys provided, so I modified the scripts a little.
Modifications I made to script include:
  • Allowing for showing multiple keys for a given command
  • Simplified the join operations on the modifiers, and allowed for usage of symbols, if one are so inclined
  • Changed the second listing to only show commands without a hotkey, and as a result I also removed the hotkey column for that listing
  • Provided in-code examples of how to sort on either columns by changing which .sort() command is commented or not
With these listing I can now easier find conflicting hotkeys (even if more than two commands use the same key combination), and also easier see commands available for hotkeys.
New variant of Commands vs Hotkeys
### Commands with hotkeys sorted by name
```dataviewjs
function joinModifiers(modifiers, symbols=false) {
	return modifiers.join(' ')
	                .replace('Mod', symbols ? '⌘' : 'CMD')
    	            .replace('Alt', symbols ? '⌥' : 'OPT')
    	            .replace('Ctrl', symbols ? '⌃' : 'CTRL')
    	            .replace('Shift', symbols ? '⇧' : 'SHIFT')
function getHotkey(arr, highlight=true) {
    let hi = highlight ? '**' : '';
    let keys = []; // Store all key combinations defined for this command
    let currKey = ""
    // Find the default key setting for the command, if any
    if (arr.hotkeys && arr.hotkeys.length > 0) {
      console.log(arr.hotkeys)
      for (let aKey of arr.hotkeys) {
    	 keys.push(joinModifiers(aKey.modifiers) + ' ' + aKey.key)
    // Handle custom hotkey setup, with possible multiple assignments
    let ck = app.hotkeyManager.customKeys[arr.id];
    if (ck) {
      // Reset keys array, as custom keys override the default key setting
      keys = []
      for (let aKey of ck) {
    	 keys.push(hi + joinModifiers(aKey.modifiers) + ' ' + aKey.key + hi)
	return (keys.length != 0) ? keys.join('<br />') : 'none';
let cmds = dv.array(Object.entries(app.commands.commands))
    .where(v => getHotkey(v[1]) != 'none')
    //// Choose your sorting option by changing which line is commented out
    .sort(v => v[1].id, 'asc'); // Sorted by the command name
    // .sort(v => v[1].id, 'asc'); // Sorted by the descriptive name
    //.sort(v => getHotkey(v[1], false), 'asc'); // Sorted by hotkey
dv.paragraph(cmds.length + " hotkeys. " +
    "Both 'default' and <strong>'custom'</strong>.<br><br>");
dv.table(["Command", "Name", "Hotkeys"],
  cmds.map(v => [
    v[1].id,
    v[1].name,
    getHotkey(v[1]),
### Other available commands with no key assigned
```dataviewjs
    let currKey = ""
    	 keys.push(aKey.modifiers.join(' ')
    	               .replace('Mod', 'CMD')
    	               .replace('Alt', 'OPT')
    	               .replace('Ctrl', 'CTRL')
    	               .replace('Shift', 'SHIFT')
    	            + ' ' + aKey.key);
    if (ck) {
      // Reset keys array, as custom keys override the default key settings
      keys = []
    	 keys.push(hi + aKey.modifiers.join(' ')
    .where(v => getHotkey(v[1]) == 'none')
dv.paragraph(cmds.length + " commands. " +
    "Rest of commands which doesn't have any keys assigned to them.<br><br>");
dv.table(["Command", "Name"],
  cmds.map(v => [
    v[1].id,
    v[1].name])
In the image below you can see the top part of the hotkeys currently defined for me, with some interesting (constructed!) conflicts.
See for example how Cmd P is connected to both opening the command palette, opening a daily note, and open the next daily note. Kind of stupid setup, so I need to fix that soon! :grin:
In addition one can see that for the first command, Navigate back, both Cmd Home and Opt ArrowLeft are valid combinations.
Whilst working with this we’ve got a FR re-opened, see A way to find which command is bound a specific hotkey, so please show some love to that, to get more attention to issues related to resolving hotkey conflicts, and to locate what a given command does.
I also found a plugin, see forum post in Show only assigned hotkeys - #3 by ichmoimeyo, which could display hotkeys on a visual image of the keyboard. Sadly, it’s in the early stages of development, and it doesn’t do the correct thing on Mac (as of today).
This question was also posted in the Help category, and solved there.
is it possible to create a bar chart from sum of different inlinefield ?
İ have a tag logbook and inlinefield games:: I ve been trying this one month now :frowning: I am using obsidian charts
Solutions
