Open Control Palette (Ctrl+P) and try to find all of options there. You will learn that the following are missing:
Open in new tab
Open to the right
Open in new window
Make a copy
Star
This also means that I can’t define a hotkey for any of those actions. This is a pity, especially in case of “Make a copy” function.
Additionally, some of items from the original context menu are also missing from the three-dot file-specific menu, even though they by all logic should be there as well.
I expect all the file context menu items be available:
in Command Palette
three-dot menu
available in the list of hotkeys
Operating system:
Linux Mint 21.1 Cinnamon
Debug info:
Obsidian version: v1.1.16
Installer version: v0.15.9
Operating system: #66-Ubuntu SMP Fri Jan 20 14:29:49 UTC 2023 5.15.0-60-generic
Legacy editor: off
This surprises me. My impression has been that everything is in the command palette and some of it is also exposed elsewhere. Offhand I can’t point to a concrete source of that impression other than the palette is where the most commands are (I imagine if I sat and thought I might remember something I already knew isn’t in the palette). Obviously my mistake hasn’t caused me any practical problems. I don’t know if many people believe the same thing.
I understand that some of the file explorer context menu items are not in the three-dot menu for mostly space and clutter reasons, but I don’t understand why some commands must necessarily be invoked only by mouse and there is no way to use a keyboard.
I personally care mostly about the “Make a copy (duplicate)” command myself.
