Canvas 'Overview' mode - where only titles are shown (hide note body)
### Use case or problem
Large canvases tendency to overwhelm of too much information on the page.
Use case: High level overview in canvas, with ability to ‘zoom in’ at various levels of granularity from map → node → note → block**
### Proposed solution
Command-palette item to toggle hide note content, and show only titles in canvas view.
### Current workaround (optional)
Resizing notes in canvas view to only show the title
### Related feature requests (optional)
https://forum.obsidian.md/t/with-demo-canvas-hotkeys-for-adding-items-navigating-and-changing-color/49318/3
Only having the title would be too small for me. Assumes I remember the content of each title, which might not be true for very large canvasses.
So perhaps 2 levels of bulk-folding, titles-only, and titles + headings.
However, even if you don’t remember the title of each note, combined with a collapsible sidebar, it wouldn’t matter
Still wouldn’t work for me. I’d far prefer an adjustable minimised setting.
That’s possible already by dragging to expand each note - Doing it in bulk would be extremely useful though, it sounds like something like a bulk slider would be more useful for your use case
This app has a great implementation of mindmap vs ‘aerial’ view
being able to only show the title would also be a requirement for me. Nothing too fancy - just show/hide note content
Another easy implementation would be a simple command to convert a note to a card with link to the note, and vice versa.
Right now when I want to reference an existing note in a canvas, I’ll often create a card with a link to the note rather than embed the note itself.
Exactly for this purpose (show only headlines in canvas elements) I am trying to create a css snippet. But it would be much easier and more elegant to do it with a single click.
This would be amazing. Honestly, the fact that it doesnt have this feature is the only reason I don’t use it. I would love to use canvas to organize my notes into categories and such. If i forget what a card is i can click on it and be taken to the note, having all the info right there in the canvas, for my use, 99% of the time, just isnt nessesary, but it’s really frustrating to have to resize every note I bring in when i’m organize brainstorming in bulk notes
YES!!! I have the same problem, and have to use the resize workaround.
Perhaps this could be an item-specific setting for each item on the canvas (RightClick > Hide Body)?
I’m building a canvas mostly using my existing notes, and sometimes I don’t need to see the entire note, just the title. I would like to be able to click on such note, and then have the said note open in a specific tab or pane in my workspace. This would allow users to use the canvas as a way of browsing notes…
+1, this would be really helpful for larger Canvas
Bumping this. My usecase is I’d like to create a large family tree but don’t need to see everyone’s life story all at once on the canvas. At the moment I just keep the default small note size but it displays the title twice; once in large font inside the note and then again above the note. With an impossible to click scroll bar. Very inelegant looking.
I want the canvas to be just an overview of the names and the connections. Then be able to click on the card to go to the full note. And perhaps a plus would be to have connections that have multiple origin/ending points.
I was just trying to find a solution to do this, and I came across this page. I’ve worked out a solution that meets my needs really nicely, so I thought I’d share it.
I just put a heading in the body of the note which uses an inline query (using the Dataview plugin) to replicate the name of the note.
I can then “narrow to heading” and show only the note name in a card on a canvas. I can also add extra lines under the heading, if I want - I actually generally add an extra line that states the general type of a thing that the note is (a stereotype, if you will…).
It’s not great if I ever want to show the whole note, but that’s not something I need. I suppose I could make another heading that includes all the rest of the note but not the repeated heading, to solve that.
I do this all by defining and applying templates, with the core templates plugin, so it isn’t onerous.
oh… the inline wuery is just # `= this.file.name`
