Summary
In Obsidian 1.12.7, frontmatter aliases are correctly parsed and surfaced by autocomplete (getLinkSuggestions), but the wikilink resolver (getFirstLinkpathDest / getLinkpathDest) does not consult them. Clicking [[<alias>]] creates a new note instead of resolving to the file that declares the alias.
A targeted code-level inspection of app.metadataCache shows there is no code path in the running app that adds aliases to uniqueFileLookup, which is the only data source the resolver reads.
Create a note
Resources/general/illusion-of-knowledge.mdwith frontmatter:--- aliases: - the illusion of knowledge - the knowledge illusion --- -
In any other note, type
[[the illusion of knowledge]]. -
Click the link.
The link resolves to Resources/general/illusion-of-knowledge.md.
The link is treated as unresolved. Clicking it creates a new file named the illusion of knowledge.md.
- Obsidian: 1.12.7 (installer 1.12.7)
- OS: macOS (Darwin 25.3.0)
- Vault id:
09ee4dc563a703ee - Vault stored on Dropbox-synced folder (case-insensitive HFS+/APFS).
- Reproduces in restricted mode (community plugins disabled), per testing.
- Reproduces after a full
IndexedDB/cache wipe and clean rebuild. - Reproduces on multiple files independently — vault-wide, not file-specific.
Community plugins enabled at time of report: calendar, dataview, homepage, obsidian-icon-folder, obsidian-outliner, obsidian-tasks-plugin, open-vscode, periodic-notes, quickadd, templater-obsidian. (Issue persists with all disabled.)
Diagnostic evidence
The following can be reproduced via Settings → Community plugins → “Open with developer tools” → Console.
1. Aliases are correctly parsed and visible to autocomplete
app.metadataCache.getCache('Resources/general/illusion-of-knowledge.md').frontmatter.aliases
// → ["the illusion of knowledge", "the knowledge illusion"]
app.metadataCache.getLinkSuggestions().filter(s => s.alias?.includes('illusion'))
// → returns objects with the file and each alias (autocomplete works)
2. The resolver returns null for aliases
app.metadataCache.getFirstLinkpathDest('the illusion of knowledge', '')
// → null
app.metadataCache.getFirstLinkpathDest('illusion-of-knowledge', '')
// → TFile (filename works)
3. uniqueFileLookup (the resolver’s only index) has no alias entries vault-wide
const u = app.metadataCache.uniqueFileLookup.data;
const keys = Array.from(u.keys());
keys.length;
// → 2873 (matches file count)
keys.filter(k => k === 'the illusion of knowledge.md');
Across the whole vault (18 files with aliases in frontmatter, 20 aliases total), zero are present in uniqueFileLookup.
4. The resolver source has no alias branch
String(app.metadataCache.getLinkpathDest).includes('alias')
// → false
The decompiled resolver:
function (e, t) {
if (e === '' && t && (f = this.vault.getAbstractFileByPath(t)) instanceof TFile) return [f];
var n = e.toLowerCase(), i = nu(n), r = null;
if (i.contains('.')) r = this.uniqueFileLookup.get(i);
if (!r) { i = nu(n = (e + '.md').toLowerCase()); r = this.uniqueFileLookup.get(i); }
if (!r) return [];
// ... path matching only
Only consults uniqueFileLookup. Never reads frontmatter.aliases.
5. The metadata-cache parser does not register aliases
computeFileMetadataAsync only adds the filename:
this.uniqueFileLookup.add(e.name.toLowerCase(), e); // filename only
A walk of the entire app object tree finds three callers of uniqueFileLookup.add: initialize, computeFileMetadataAsync, onRename. None of them add aliases. Searching for any function whose source contains both uniqueFileLookup and alias returns zero results.
6. Instrumented re-parse confirms zero alias add calls
const u = app.metadataCache.uniqueFileLookup;
const orig = u.add.bind(u);
const log = [];
u.add = (k, f) => { log.push({k, f: f.path}); return orig(k, f); };
const f = app.vault.getAbstractFileByPath('Resources/general/illusion-of-knowledge.md');
await app.metadataCache.computeMetadataAsync(f);
// log shows zero entries for any alias key — only the filename gets added
Workaround
A small plugin that listens to metadataCache.on('changed'), reads frontmatter.aliases, and adds each alias as (alias + '.md').toLowerCase() to uniqueFileLookup.data makes resolution work correctly. The fix takes ~30 lines of code, suggesting the missing registration in the core is a small omission.
Question for triage
Is the resolver supposed to consult uniqueFileLookup for alias entries (and the parser is missing the registration), or is there a separate alias index that’s supposed to be created elsewhere? Either way, in this build the data path is absent.
