When a code block contains <<, the code block will be rendered to the end of the article in edit mode
When a list appears, add a code block containing the characters >> after the shift enter line break, and indent the entire code block to match the list. The code block in edit mode will never stop and continue
  1. test
    # syntax=docker/dockerfile:1
  2. HereDoc
    FROM ubuntu:22.04
    RUN <<EOF
    echo "Hello" >> /hello
    echo "World!" >> /hello
    EOF
  3. test
YES
The code can be stopped normally
bug
Obsidian version: v1.5.12
Installer version: v1.5.12
Plugins installed: 0
Plugins enabled: 0
In addition, when the code block is indented, the indentation line on the left in edit mode is not a straight line but broken into two segments. When can this small problem be fixed btw? It looks too inelegant and this problem has persisted for several years. Thanks for your hard work.:heart:
Please read carefully, my problem is different from his, my problem is 《When a code block contains <<, the code block will be rendered to the end of the article in edit mode》,To avoid ambiguity, you can change the title and use my modified description
Ahh, yes. I thought that was the catch all topic for code blocks in lists. It seems more like this one:
I changed the topic title per your suggestion.
Well, 2022…anyway, looking forward to the day when it will be repaired, thank you :pray:
This is a duplicate of
