'<<' in shell codeblock breaks formatting
  • create a new document with the following content:
- list:
```shell
cat << EOF > /tmp/file.txt
line 1
this line’s formatting gets broken
  • indent all content between and including the ‘```’ characteres.
The formatting of the last line “this line’s formatting gets broken” should not change
The formatting of the last line “this line’s formatting gets broken” did change.
If one of the ‘<’ characters is removed, the formatting behaves as expected.
  • Operating system:
  • Debug info:
    Obsidian version: v0.13.23
    Installer version: v0.13.23
    Operating system: Windows 10 Pro 10.0.19044
    Legacy editor: on
    Community theme: Atom
    Snippets enabled: 1
    Safe mode: off
    Plugins installed: 7
    Plugins enabled: 5
    1: Advanced Tables
    2: Dataview
    3: Obsidian Git
    4: Outliner
    5: Sliding Panes (Andy’s Mode)
Custom theme: for cosmetic issues, please first try updating your theme to latest. If still not fixed, please try to make the issue happen in the help vault or disable community theme and snippets.
Community plugins: for bugs, please first try updating all your plugins to latest. If still not fixed, please try to make the issue happen in the help vault or disable community plugins.
images below of the issue reproduced in the help vault:
This behaviour occurs in the new and legacy editors.
thanks
upstream report
  1. Create note with two code blocks (see attachment for full test note)
    obsidian-bugs-bash<<EOF.md (290 Bytes)
1.1.
cat <<EOF
Line 1
Line 2
EOF
1.2.
echo test
  1. Put first code block inside quote block. Now formatting in edit mode is broken.
  2. Add any non-letter character between << and EOF e.g. <<-EOF. Now formatting should be fine.
Intended code block with <<text shouldn’t break formatting for further code blocks inside editor mode.
Code blocks after <<text inside quoted code block will be displayed as plain text inside editor mode, it will be fine in reading mode.
  • Operating system: Linux Manjaro
  • Debug info:
	Obsidian version: v0.15.9
	Installer version: v0.15.9
	Operating system: #1 SMP PREEMPT Thu Aug 11 13:14:01 UTC 2022 5.10.136-1-MANJARO
	Legacy editor: off
Tested inside sandbox vault.
any updates on this bug?
