see screenshot at the bottom for better clarity
- # header
- normal text
- ## Project Alpha Meeting Note - #### Item 1 cannot be implemented yet - conflict with another feature - Item 2 pending UAT - scheduled for next Monday
- conflict with ...
- ### Project Alpha ...
^blockref
we don’t support linking to headers in list. Either use the block linking or search/open a feature request for this.
I’ll search/open feature request then. Coz I cannot find any other way to link to that particular list-block when it’s a header (I cannot even do manual block id).
Thanks.
Ok, while reviewing your report I discovered another issue. I created a bug report for it.
You can still create a feature request for header linking (not block linking of header)
Thanks. Appreciate that. On that note, I found an existing feature request per links below (and upvoted them). If the bug is fixed, probably can close these feature requests as well.
Also, I noted your response (and Licat’s) on supporting header in another post (link below). I guess it’s probably tricky to implement for now. Ability to do block reference (with block id) would be sufficient for me.
