Block references work inconsistently across different types of lines. For subheadings, items in marked lists, quotes, etc they work just fine but for most combinations of those, block references are broken.
For example, if I try to reference a quote that is inside a marked list with the [[^^ syntax, it doesn’t show up on the suggestions list.
Since I structure all my notes as nested marked lists, this often breaks my working process.
To make ^abc123-like references work for any given line.
Current workaround
When I need to have a reference to a line, I change it to make it searchable with the [[^^ syntax. Then, when the reference link (the ^abc123-like) is created, I change the line back to the desirable form.
An example of all steps a line undergoes...
- > Quote inside a marked list
- Quote inside a marked list
- Quote inside a marked list ^abc123
- > Quote inside a marked list ^abc123
Unfortunately, when I change the line back, the reference gets broken and is not displayed in the popup window anymore:
Related feature requests and bugs
(It can be considered closed when this one is closed.)
Block references work, but individual lines can’t be referenced unless they are formatted as discrete blocks.
The manual says:
A “block” can be a paragraph, a blockquote, a list item, etc. In general, anything that has empty lines before and after is a block.
If a quote is inside a list, it won’t have empty lines before and after it, so it can’t be considered a block or linked to.
Angel
  1. You can’t put headings inside a list item in Markdown.
  2. To put a quote inside a list item it must be indented.
Oh, I see. Well, it seems there’s no way around this, right? Like, probably that would be too much of an undertaking to redefine what a basic markdown entity (like a block) is.
I think you’re absolutely right.
Block-level referencing is relatively easy to target with markdown syntax, and it is probably a good-enough delimitation for most use cases.
But this is a feature request, so line-level referencing might come in time
Angel
+1 on this feature request.
I’ve been using Outliner & Indentation Guide plugin for my daily journal. And some of the bullets I formatted them as headers for sectioning and better readability. But now I’ve stumbled upon that I cannot do block reference to that particular header-bullet.
Would like to see this feature happen.
