Hi there!
I’ve never used Obsidian Publish, but it indeed looks like you would have to copy Ficus Ruby’s CSS to the end of your publish.css file, and without the ficus-ruby class since Obsidian Publish seems to lack a way of adding classes. So try copying all of this and put this on the end and it should work:
body {
--link-external-color: #fa858f;
&.theme-dark{
--graph-line: #fa858f;
.dropdown {
background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' width='292.4' height='292.4'%3E%3Cpath fill='%23C94458' d='M287 69.4a17.6 17.6 0 0 0-13-5.4H18.4c-5 0-9.3 1.8-12.9 5.4A17.6 17.6 0 0 0 0 82.2c0 5 1.8 9.3 5.4 12.9l128 127.9c3.6 3.6 7.8 5.4 12.8 5.4s9.2-1.8 12.8-5.4L287 95c3.5-3.5 5.4-7.8 5.4-12.8 0-5-1.9-9.2-5.5-12.8z'/%3E%3C/svg%3E%0A");
body.theme-light {
--background-primary: #f5f5f5;
--background-primary-alt: hsl(180, 13%, 86%);
--background-secondary: #b0c6c2;
--background-secondary-alt: #d7e0e0;
--background-modifier-border: hsl(45, 27%, 65%);
--background-modifier-form-field: #fff;
--background-modifier-form-field-highlighted: #fff;
--background-modifier-box-shadow: rgba(0, 0, 0, 0.1);
--background-modifier-success: #a4e7c3;
--background-modifier-error: #990000;
--background-modifier-error-rgb: 230, 135, 135;
--background-modifier-error-hover: #bb0000;
--background-modifier-cover: rgba(0, 0, 0, 0.8);
--link-color: #800000;
--link-color-hover: #c94458;
--text-normal: #333834;
--text-muted: #525e5b;
--text-muted-rgb: 136, 136, 136;
--text-faint: #525e5b;
--text-error: #800000;
--text-error-hover: #990000;
--text-highlight-bg: rgba(201, 68, 88, 0.3);
--text-highlight-bg-active: rgba(255, 128, 0, 0.4);
--text-selection: rgba(242, 186, 179, 0.66);
--text-on-accent: #f2f2f2;
--text-title-h1: hsl(159, 17%, 41%);
--text-title-h2: #417262;
--text-title-h3: #E3764F;
--text-title-h4: #E66D9B;
--text-title-h5: #9359db;
--text-title-h6: #4065dc;
--interactive-normal: #f2f3f5;
--interactive-hover: #e9e9e9;
--interactive-accent: #c94458;
--interactive-accent-rgb: 201, 68, 88;
--interactive-accent-hover: #c94458;
--interactive-success: #333834;
--scrollbar-active-thumb-bg: rgba(0, 0, 0, 0.2);
--scrollbar-bg: rgba(0, 0, 0, 0.05);
--scrollbar-thumb-bg: rgba(0, 0, 0, 0.1);
--highlight-mix-blend-mode: darken;
body.theme-dark {
--background-primary: #305654;
--background-primary-alt: #1e3735;
--background-secondary: #305654;
--background-secondary-alt: #1e3735;
--background-accent: #fff;
--background-modifier-border: #e8aa99;
--background-modifier-form-field: rgba(0, 0, 0, 0.2);
--background-modifier-form-field-highlighted: rgba(0, 0, 0, 0.5);
--background-modifier-box-shadow: rgba(0, 0, 0, 0.3);
--background-modifier-success: #197300;
--background-modifier-error: #361c1e;
--background-modifier-error-rgb: 61, 0, 0;
--background-modifier-error-hover: #563032;
--background-modifier-cover: rgba(0, 0, 0, 0.6);
--link-color: #fa858f;
--link-color-hover: #f4465d;
--text-normal: #f9ead9;
--text-muted: #d5c4a1;
--text-faint: #bdae93;
--text-highlight-bg: rgba(181, 118, 20, 0.5);
--text-selection: rgba(89, 75, 95, 0.99);
--text-title-h2: #DADC8F;
--text-title-h3: #a5e6f9;
--text-title-h4: #D1ABFF;
--text-title-h5: #FFA3C6;
--text-title-h6: #e8bb89;
--text-on-accent: #fbf1c7;
--interactive-normal: #f4465d;
--interactive-hover: #f9a8b1;
--interactive-accent: #f4465d;
--interactive-accent-rgb: 205, 123, 130;
--interactive-accent-hover: #f9a8b1;
--scrollbar-active-thumb-bg: rgba(0, 0, 0, 0.4);
--scrollbar-thumb-bg: rgba(0, 0, 0, 0.2);
--inline-code: #b48ead;
--code-block: #b48ead;
--pre-code-bg: rgba(0, 0, 0, 0.2);
--blockquote-border: #b57614;
--vim-cursor: #d65d0e;
--border-color: #504945;
--hover-bg: rgba(0, 0, 0, 0.5);
body.theme-light .is-selected kbd {
background-color: var(--background-secondary-alt);
body.theme-light .view-header {
border-top: 1px solid var(--background-primary-alt);
border-bottom: 2px solid var(--background-primary-alt);
background-color: var(--background-primary-alt);
// This is JAG's change but can't remember why he wanted it
body.plugin-sliding-panes-rotate-header .workspace > .mod-root > .workspace-leaf > .workspace-leaf-content > .view-header > .view-header-title-container:before {
background: linear-gradient(to top, transparent, transparent)!important;
body.plugin-sliding-panes-rotate-header .workspace > .mod-root > .workspace-leaf > .workspace-leaf-content > .view-header > .view-header-title-container:after {
body.theme-light .workspace-ribbon.mod-right.is-collapsed {
border-left-color: var(--background-secondary-alt);
body.theme-light .workspace-ribbon {
border-left: 2px solid transparent;
body.theme-light .status-bar {
border-top: 2px solid var(--background-secondary-alt);
body.theme-light .view-action {
color: var(--text-muted);
body.theme-dark .view-action {
body.theme-dark .suggestion-item.is-selected {
background-color: var(--link-color-hover);
body.theme-dark .workspace-ribbon.mod-right.is-collapsed {
body.theme-dark .workspace-ribbon {
body.theme-dark .status-bar {
