Thanks, it helped. It looks a tiny bit weird because question marks and such are a bit smaller than text but it works.
I hope I won’t have to bother you anymore. :wink:
Thanks a lot :+1:
Thank you, I really enjoy using this theme, especially the Ficus Ruby color scheme!
Edit: I’ve started using Spectral on my e-reader. If there’s some other typefaces for screens that you really like, I’d love to hear about them!
Hi all, it’s been a while! I’m releasing some small quality of life updates today as Typomagical 1.1:
Features
  • Links: Change default Link font from Spectral SC to Alegreya SC, which has a shorter x-height and should be easier to read.
  • Added a Style Setting to change link font from Alegreya SC to Spectral, which is the same as the body text.
  • Added an option to use Circled Numbers for Ordered Lists:
  • Add Vileplume’s blockquote as an option
  • Add an option for justified text
  • Control line height with style settings
Fixes
  • JAG’s Ficus Ruby changes
Typomagical v1.2
Hi everyone! For version 1.2 I’ve added some new settings for you to play with:
  • Sans Serif body font as an optional new setting. I’ve chosen Source Sans Pro, because it has an x-height that matches Spectral, and it has a curly lower case “L” which I enjoy
  • Gradient on H1/Title as an optional new setting. See how it looks above! For now it looks best with dark themes, while I tweak the colours.
  • Background color - Pick whatever color you like!
  • H1 alignment - Now you can left align the title
Hope you’re all enjoying Typomagical :slight_smile:
