Start absolute path with a leading slash /
In Obsidian there are the following options for ‘New Link Format’:
  • Shortest path when possible
  • Relative path to file
  • Absolute path in vault
I use ‘Absolute path in vault’ because I sync my notes using Git to a private Gitea instance (though it would be the same if I were using GitHub for example). I also view my notes in other apps sometimes.
Using this link option, I would typically get a link which looks like this:
[Note 1](L1folder/L2folder/note.md)
The problem is that I have to manually add a ‘/’ onto the beginning of the path every time to maintain compatibility with other apps. It would be great if I didn’t have to do that, but the main problem is actually if I decide to rename a note. In that case, Obsidian automatically updates all the references to it (great!) but it will strip this leading ‘/’ character and I would have to go through and amend everything again manually.
It would be great if the absolute path included the starting ‘/’ to show that that was the beginning of the path. This would need to take effect both when generating the link for the first time and also when updating the links after a note rename/move.
Current workaround
  • Manually adding the ‘/’ when creating links
  • When renaming or moving notes, I have to find all automatically updated references using Git and then add the ‘/’ manually
Related feature requests
I only found one related post on the forum so far about this and there had been no response:
this is unlikely to happen since it will break the nested vault workflow. A leading / also generally means “from the root of the filesystem” not “from the root of the vault”. I am not sure how that would help with compatibility.
It is likely that ./ will be added in relative path mode.
Nested vaults are not something I use myself so I’m not too familiar with how they work, but if my request would cause an issue with another workflow then it could always be done as a setting so hopefully then everyone is happy :grin:
Maybe the existing setting could be extended with another option which includes the leading ‘/’, or an extra field could be added allowing an optional/user-defined leading character (or characters, then the same setting could also be used for the ‘./’ you mentioned for relative paths).
I encountered this problem. The ./ is necessary for markdown links to work correctly with VuePress. Obsidian Apply Patterns plugin helps me to solve this issue in the current Obsidian functionality.
Find (\]\()(\w) and replace to $1./$2
The same request is made here to add the option to start absolute paths with ‘/’.
It would be awesome to have the option to turn it on. A warning could be made that nested vaults then don’t work with it.
The absolute links format is not really considered absolute by other tools, such as when displaying notes backed up on GitHub in browser. If I have vault-root folder _media and link such as [](_media/cat.png) inside a pets/cat.md note, GitHub will resolve the image path as pets/_media/cat.png.
While I understand handling this may be left up to implementation, a truly absolute link, one beginning with / (i.e. [](/_media/cat.png)) seems to work in both Obsidian and GitHub. The problem is that there’s no option for Obsidian to automatically place starting / in the link, making this manual effort and error prone.
An option to start absolute links with /.
I’ve tried to put /_media in “Attachment folder path” option to at least handle pasted images, but the / gets trimmed so there doesn’t seem to be any workaround.
Agreed that a clean way to indicate “relative to vault root” vs. “relative to local folder” is needed. The absolute path specification works if the application has an awareness of a “domain root” (Vault root in Obsidian, repo root in Github). But becomes problematic when opening the file in filesystem-centric applications – e.g., Vim or some other text editor. Here, the current convention works if the editor or other application working directory is set to the vault/project root, but of course breaks with the leading “/”, as this is now interpreted as the filesystem root. It would be nice if there was a convention that worked across both contexts, but that might be too complicated
Related: maybe relative paths should automatically (or linted to) start with “./_media/cat.png” as well to minimize ambiguity between local/relative and absolute paths in both Obsidian and non-Obsidian contexts?
The reason why this is not added is to support nested vaults.
For relative mode:
I wasn’t aware of nested-vaults being a thing, so read up quickly on them and I don’t understand the relation between them and leading /.
The only case I can imagine this being relevant is when creating link in note in sub-vault, and then opening that note in the primary vault. But:
  • Does that even work as of today? Will Obsidian consider the origin of the link to be in the sub-vault when note is opened from primary vault?
  • Aren’t such sub-vault links then actually relative to the sub-vault? Why call them absolute?
In any case, the ask was to make it an option - that could come with a note to not turn it on for nested vaults. But I don’t see why one use-case should block another.
I agree with BetaRavener. I would really need this option to make Obsidian work seemlessly with Vimwiki.
It already works 98%. That would make it awesomely compatible 100%.
