Here’s three macros for Keyboard Maestro on macOS. As ever, this is provided as-is, but I’ve tried to make it easy to set up.
Change the location of the vault in the yellow action on each macro before use.
- Save workspace
- Save Workspace asks you to specify a name for the current layout, then stores a copy of
.obsidian/workspacein your Obsidian Vault in a newworkspacesfolder.
- Open workspace
- Open Workspace asks you to choose one of the workspaces you’ve saved. It looks up the workspace file saved as per above and replaces the current workspace file with that one, then reloads Obsidian. As a result, you get your saved set of notes and panes opened again.
- Delete workspace
- Delete Workspace deletes the selected saved workspace.
