Sanctum v0.3.1 is here!
Changes, fixes and additions!
- Updated font snippet on github to add IBM Plex Sans and Mono, as well as a fix for fold indicators;
- Added Custom icon Replacement for the BRAT plugin sidebar icon, as well as for the WordSprint plugin icon;
- Formatted suggestion flairs so when transcluding headings, they don’t overlap the title;
- Added pseudo kanban class. Just add
cssclass: kanban at the beginning of the note, and it will format lists into kanbans. Do note that any list inside that note will become a kanban;
- You can now change Edit Mode font size with the
Ctrl+Scroll, like in default obsidian;
- Fixed sidebar in mobile, and centered the icons;
- Added more Task / Checkbox options. These are all the available options now:
- [⭐] Star
- [a] Alarm / Reminder / Notification
- [❤] Favourite
- [s] Savings / Piggy bank
- [S] Savings alternative / Piggy bank
- [-] Cancelled
- [>] Rescheduled / Forwarded
- [<] Scheduled
- [l] Location
- [1] Success / Round Checkbox
- [B] Bug / Debug
- [X] Failure
- [n] Note / Annotation
- [p] Pros
- [c] Cons
- [W] Win / Success / Reward
- [b] Bookmark / References
- [I] Idea / Tip
- [!] Important / Attention
- [?] Question / Cue
- [i] Info
- Lists should have a bit more white space;
- Added Pseudo-Admonitions. Just add
cssclass: admonitions at the start of the note in order to turn custom checkboxes into admonitions. You can indent (remember, it’s a list) in order to include more information in the admonitions! Note that only the following turn into admonitions:
- [B] Bug / Debug
- [X] Failure
- [p] Pros
- [c] Cons
- [I] Idea / Tip
- [i] Info
If you happen to have a suggestion / request for more, just submit an issue over on github!
Style Settings:
- Added accent color as active line highlight option to Style Settings;
- Added options for Edit and Preview mode Heading fonts, as well as Heading colors and background colors, each with a toggle;
Publish:
- Formatted “Publish changes” page;
- Added Publish css for anyone who wants to use the theme for your public vault. Do note that this is somewhat experimental! In order for it to work correctly, you’ll have to toggle “Readable line length”, and have “Use sliding windows” off. There’s a bit of css trickery in order for it to show the asides in desktop screens. I’ll look into different options to better achieve this in the future.
