Rename folder with shortcut f2 in left collapse / sidebar
Basicially this Feature Request but with folder: Add F2 rename note hotkey in left collapse / sidebar
I want to quickly rename the folder with f2 in sidebar on desktop (win10).
  1. Select Sidebar Folder
  2. Press F2
  3. Edit Foldername
Current workaround
  2. Right click
  3. Click Edit
  4. Edit Foldername
Additional info
Current version I tried: v1.3.4.
Only using default core plugins.
Found nothing mentioned in the forum.
If there is already a native solution that I have overlooked, I would greatly appreciate it if someone could bring it to my attention.
Thanks in advance!
Alt/Opt + Click the folder you want to rename then press F2.
