When you are linking to blocks as part of a workflow where the links are meant to be temporary, it can be somewhat cumbersome to delete the link and the block id after the fact.
Let there be a command to remove block link and block id. This would be accessible by right clicking on the block link or block id. If there were more than one link to the block, a dialog would inform you of the other instances. To be clear, this would not delete the block, just the block id and the block links.
Related feature requests
I previously created this request: Right click menu option to delete link and file. So, I realized the similar functionality would be helpful when I saw this thread: Delete unused block reference IDs.
Thanks!
