[Mobile] Swipe the navigation toolbar to switch between tabs
Switching between tabs on mobile isn’t very fast.
Swiping the toolbar similar to how you can in Firefox and Chrome on Android to move between tabs would be great.
You can add “next tab” and “previous tab” to the mobile toolbar, but that only shows when editing notes.
You could use my toolbar to add a button with a tap action leading to the next tab and a long-press action leading to the previous tab. I hope to add swipes like you describe later.
Looks cool and love the philosophy, but I started using a keyboard called FlickBoard that has Ctrl and Tab buttons so now I switch between tabs with Ctrl + Tab and Ctrl + Shift + Tab.
My workaroud/solution for now:
Swipe the mobile navigation toolbar to switch between tabs - Share & showcase - Obsidian Forum
