Finally, a seamless mobile toolbar!
The Most Colorful Obsidian Toolbar
A vibrant, fully customizable toolbar that floats above the keyboard, replacing the default toolbar. It’s called “gay” because because I’m a queer freak who laughs in the face of the “no politics” chillng effect of corporate tech contexts. I am my work. This isn’t just a tool – it’s an expression of my creativity, my passion, my identity, and my joy. And in a time when so many queer people in the U.S. are enduring new waves of hostility and fear, this is my small act of defiance:
“Technology presumes there’s just one right way to do things, and there never is.”
—Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance*
Highlighted Features
  • Customizable Toolbar:
    • Move (via dragging), add, remove, and personalize buttons (color, icons, and commands).
    • Button slots can remain empty, creating gaps in the toolbar if desired.
    • Save and load configs – freely experiment and return to layouts you know work for you if you get lost.
  • (Up To) Two Commands Per Button:
    • Primary Action: Triggered by a tap.
    • Secondary Action: Triggered by a long press (tap and hold for a customizable duration, default: 200).
    • Both actions can have distinct, customizable icons.
  • Smart Icon Colors:
    • Icon colors are automatically chosen to maximize contrast against button background colors, using perceived luminance.
Toolbar Edit Mode
Main Settings (if no button is selected)
  • The default config includes a :wrench: wrench icon in the top right -— tap it to enter Edit Mode, or run Gay Toolbar: Toggle Edit Mode via the Command Palette.
  • Save the current config and load previous saved configs anytime via the “Saved Configs” modal.
  • Use a custom background (your own css value, eg radial-gradient(circle at bottom, pink, grey, white)).
    Screenshot 2024-12-19 at 11 59 59 AM
Button Settings
  • Add Buttons: Tap an empty slot (+) to insert a button (new button color is chosen randomly from color presets – edit these in the color picker modal).
  • Edit Buttons: Tap an existing button to change its primary action/icon (bottom right button), secondary action/icon (top left button), or color, or to remove it.
  • Drag & Drop: Long-press to initiate a drag operation to move buttons. If you drop a button on a non-empty slot, the button in that slot swaps positions with the one being dragged.
  • Secondary Actions: Assign a long press command with its own icon for each button as desired. The press duration is user-configurable in the main settings via the Long-press delay option. Personally, I like to group related commands like undo/redo and indent/outdent.
    Screenshot 2024-12-19 at 12 02 05 PM
Roadmap
If you’re excited about seeing any of these or other ideas implemented, I’d love to collaborate! I’m happy to hop on a call and pair-code with you, even if you’re new to coding. What matters most to me is our shared investment in shaping our tools to meet our needs — I cherish connection built on loving the technology that supports us.
  • Show/Hide Toolbar: Add a toggle command to hide the toolbar, leaving one floating, movable button that slides the toolbar in on tap.
  • Time-dependent Colors: Automatically change toolbar colors based on time (daily or even every second).
  • Better Icon Support: Add emoji support to icon selector.
  • Separate Icon and Command Selection Flow: Also, display the selected command names/ids. This will require overhauling the existing button settings screen.
  • Swipe Button Actions: Add additional swipe gestures for more commands (e.g., swipe up, down, left, right). Visual cues will display custom colors for each gesture on the border of each button and dynamically as the user swipes. Example button for block editing:
    • Tap: Select the current block.
    • Long-Press: Copy the current block.
    • Swipe Left: Outdent.
    • Swipe Right: Indent.
    • Swipe Down: Move the block down.
    • Swipe Up: Move the block up.
“What’s wrong with technology is that it’s not connected in any real way with matters of the spirit and of the heart, and so it does blind, ugly things quite by accident and it gets hated for that. People haven’t paid much attention to this before because the big concern has been with food, clothing, and shelter for everyone, and technology has provided these. But now, where these are assured, the ugliness is being noticed more and more and people are asking if we must always suffer spiritually and aesthetically in order to satisfy material needs.”
