Small issue with tags that are âmisspelledâ. Take the following:
If you turn on spellcheck and thereâs a red squiggle under something that the app thinks is âmisspelledâ, it breaks the way tags look in the UI (which also makes the tag a bit difficult to edit, since it seems to show spaces where there arenât any).
Note: both of the above tags are valid, as far as Obsidian is concerned (they show up in the tags view)
I know I can fix this by just adding the word to the dictionary, but itâs come up often enough while typing to be slightly annoying, especially when youâre in the midst of typing a tag and itâs incorrectly spelled right now but youâll be fixing it shortly or just simply havenât finished typing yet.
