Meta Post - Hotkeys
Yeah, I knew, I forgot to mention a link to yours, But this has more details, I have presented more arguments.
In addition to that it has more other hidden request,
for e.g. Currently as of 2020-12-13T18:30:00Z, Obsidian do not have an option to set Hotkey for Starting Presentation, And I have suggested one.
My bad, I gave a narrow heading. Thanks
I was searching for, how to make keyboard navigation easier, though it is not better than direct hotkey navigation, but, It will be better than using mouse.
here I will try to curate possible solutions, or JS libraries which may help to make it easier to implement.
I went ahead and strikethrough the ones you listed. I don’t mind doing this but someone has to notify me that a hotkey request has been fulfilled.
Next and previous day hotkeys in the journal would be super useful.
Exactly. What is the design choice for not allowing Function keys?
Please, add this feature request to the list:
Thanks a lot!
I’d like to be able to change the hotkeys for Next and Previous when using Find.
macOs uses cmd+G and cmd+shift+G universally for these, so F3 and shift+F3 are quite a context shift.
Hotkey for creating code blocks. I’m used to doing this in Slack with Option+Shift+Command+C
The Code block from selection plug-in provides a hotkey.
We shouldn’t need a plugin to set a hotkey for creating code blocks.
Same for this feature request: Include an option to toggle both sidebars as a hotkey. It has been archived because the proposed solution is to use a Windows-only third-party software. Well no, sidebars are UI parts and a hotkey to toggle both at the same time needs to be implemented. Can’t go in ā€œfocus modeā€ / ā€œclean viewā€ / ā€œfullscreenā€ without it.
