- Create a new canvas
- Create a first node with
$$\a$$(this should show up in red, because\ais undefined) - Create a second node with
$$\def \a{w}$$(this defines a latex macro, replacing\awithw) - Copy the first node, and paste it, so that there are now three nodes total
- Bug #1: only the pasted node will now show
w, meaning the first node didn’t update its latex after creating the macro - Save and close obsidian
- Open the canvas in obsidian again
- Bug #2: even on document reload, the macro
\ais still not applied to both the first and the third node, even though it is defined in the document
Y
I expect nodes with formerly invalid macros, to become valid when you create a macro, ie: it should refresh any latex using a custom macro, when a macro is created.
In general, latex macros seem pretty flaky in obsidian, sometimes requiring a restart, because latex globals are global per-session, if they’ve been loaded once (also mentioned in Custom LaTeX commands (global)), which, is very unintuitive. I would expect latex macros to be per-document. I would love for there to be a dedicated place to define latex macros in every document, rather than doing it in-place. I’m guessing a lot of the issues just come from how MathJax works, and the order they are loaded in
Some nodes show up as invalid, even though a valid global macro is defined
Obsidian version: v1.3.5
Installer version: v1.3.5
Operating system: Windows 10 Home 10.0.19045
Legacy editor: off
