name Add Topic
type note(New Topic) template
action Knowledge Topic Template
class dataview-button
table importance, file.mtime as Last_Modified__, pillars as Pillars__________________, habitsRoutines as Habits_and_Routines___, courses-and-training
from #knowledgeTopic
sort file.mtime desc
Status:: Active
Importance::
Goals::
Pillars::
Habits and Routines::
Courses and Training::
Relevant Resources
Notes & Ideas
table file.mtime
from ""
where contains(knowledge-topic, this.file.link)
sort file.mtime asc
Media
table file.mtime
from #media or #articles or #books or #podcasts or #tweets or #videos
sort file.mtime asc
Source
table file.mtime
from #source
sort file.mtime asc
Resources
table file.mtime
from #resources
sort file.mtime asc
Tools + Apps
table file.mtime
from #tools or #apps
sort file.mtime asc
Courses
table file.mtime
from #courses or #coursesTraining
sort file.mtime asc
In the Productivity example above I would have Knowledge Topic:: [[Productivity]] somewhere in the note for whatever course, media, note etc.
I write almost all of my metadata in field:: value syntax within the page body as dataview will recognize that format the same as it would yaml frontmatter.
I’ve written this elsewhere but here are some reasons I prefer inline metadata to yaml:
A link in yaml doesn’t show as a backlink.
If you rename a page you have linked in yaml the link doesn’t auto update like it will in the page.
yaml doesn’t allow for linking something like [[@person]] and this is how all of my people pages are titled.
I like to write inline as I find it much more natural and can give me more context.
Fields inline seem to be much more forgiving as far as syntax goes vs yaml. You can use normal lists, format with markdown, etc. yaml seems fragile to me.
This helps a lot, thank you! I’ve been dying for an alternative to YAML and wondered if the double colon was such an alternative, but I apparently didn’t search for the right thing to figure it out. Time to go change my templates!
First of all, what you are sharing is very useful so thank you.
Second, I have a quick question that I am hoping you can answer since you seem to know a lot about this plugin. I generally prefer to use fields inline as well, but it seems that it does not accept bull list values as in YAML. For example:
field::
value 1
value 2
etc
Here, the values are not recognized by Dataview! I know that I can write it as a list in one line separated by columns, but this reduce legibility of the values if they are long sentences rather than just simple words.
A workaround I’ve found is to repeat the field multiple times, ex:
field:: value 1
field:: value 2
field:: etc…
but this is quite far from being an elegant solution.
Do you by any chance know of a way to get this to work?
I’ve tried to demo this with a new Knowledge Topic called ‘Mapping’ using the Knowledge Topic template, but the ‘Notes and Ideas’ codeblock keeps pulling in all my vault files even though none contain the knowledge topic
table file.mtime
from ""
sort file.mtime asc
@arminta Hi Sarah,
For your date fields, 1) can you show how you are entering in your create/ due/defer/recurrence dates into a task?
2) how do you compute these in DV?
Ideally, I wanted to have:
CreateDate:: [[20210910]]
for example, but this doesn’t seem to fall into the DV. Tried:->
CreateDate:: date([[20210910]]) among others.
Ideally, I wanted to not need to create a new file for each task, and have the ability to add a number of variables to a single line.
