@WhiteNoise
I experienced the very same issue as @obadiahcruz
Something awful must happen behind the scenes to crash my MacPro. I’ve enough capacity on my system to run everything I want, smoothly and stable
I didn’t have Kernel Panics for ages, this makes me feel very bitter - Obsidian is awesome but I’m not too excited about its framework, Java and electron, chromium. Today many browsers use chromium but apparently many apps as well (apple store)
So I’m adding my 2 cents to this topic, and not by summarizing what others say to put myself at the center. Let me explain why I wrote what I wrote previously :
I added Plugins, because Plugins extend Obsidians code adding to a potential vulnerability, electron because the problems with electron aren’t isolated, also sleep mode, because I had a violent double shutdown KP whilst waking up my computer and working with Obsidian, themes because they interact with draw processes which might conflict, especially if the theme is malformed
I code myself for a decade already but only in ObjC, applescript and bash shell, in future I’ll learn Kotlin.
Sometimes little code corrections adjust everything bad, and you forget you ever had some problems with your code.
Obsidian keeps running 3 or 4 additional helpers in the background. Do they interact only with the gpu or more? What happens all in the background?
The graph in Obsidian is very resource intensive but we don’t use it to work, just to explore and we don’t look at it all times…
If you start to limit a process to the bone, you learn very quickly how to prevent any crashes. I would prefer if Obsidian would get a mechanism to quit itself before to cause any harm to my system.
KP are not the problem if isolated, but can’t be a constant. From the videos seen and the discussions online I know the user base of Obsidian who uses Mac isn’t a small percentage.
Because getting KP isn’t working, it’s just a mess. And with mess I don’t wanna insult anyone working on the code of Obsidian. Otherwise, I wouldn’t take the time to write my post.
I also don’t want to try with Notion because it uses electron as well. Obsidian is awesome, but let’s remove this KP for good
