Use the following file.
0. Esercizi.md (34.3 KB)
Try to link one of the last headings in that file.
Try to link the “Esercizio 64” header and click it.
I’d expect to be able to link every header in the doc.
When clicking, it should just select the relevant part of the header.
When linking, it’ll let you select “Esercizio 64” but none after. If you write it manually it won’t be accepted (as if the header didn’t exists).
When clicking on the “Esercizio 64” link, the content of the following headers will be highlighted too, suggesting it’s considered as one.
- Operating system:
Windows 10
- Debug info:
Obsidian version: v1.1.9
Installer version: v0.14.6
Operating system: Windows 10 Home 10.0.19044
Legacy editor: off
Plugins installed: 9
Plugins enabled: 6
1: Advanced Tables v0.17.3
2: Excalidraw v1.7.19
3: Outliner v3.0.0
4: Novel word count v2.5.1
5: Latex Suite v1.6.11
6: Underline v1.2.1
Works even in sandbox. Removing headers won’t make missing ones appear. Maybe it’s the length?
EDIT: Header “Esercizio 62” doesn’t appear as well and it seems it is under “Esercizio 61”. Header “Esercizio 63” works fine.
