A place to collect and/or link to AutoHotKey resources for use in Obsidian. Continuing the discussion from AHK repository:
zid = zettelkasten ID
From @crabtree
Send an email directly from inside Obsidian
I blagged the following from the ConnectedText forum. It was written by Manfred Keuhn
` & m:: ;send e-mail
Gui, Add, Edit, W300 vemail,
Gui, Add, Edit, W300 vsubject,
Gui, Add, Edit, W300 R20 vbody,
Gui, Add, Button, Default, Send
Gui, Show
Return,
ButtonSend:
Gui, Submit, NoHide
if email = Email
Return,
if message = Message
Return,
else
Run, mailto:%email%?subject=%Subject%&body=%body%
Gui destroy
return
Split the pane vertically and create a new file
@kiriappee on Obsidian forum
#IfWinActive ahk_exe Obsidian.exe
^+n::
Send ^pSplit vertically{Enter}^n
return
Entry form for bibliographical (Book) data
Adapted from the ConnectedText Forum, by @keuhnm. It creates links for the author, the title, and the publisher. The backtick hotkey might be a bit troublesome if you ever do any code highlighting.
` & b::
Gui, Add, Text, x6 y17 w80 h20 , Author:
Gui, Add, Text, x6 y47 w80 h20 , Title:
Gui, Add, Text, x6 y77 w80 h20 , Place:
Gui, Add, Text, x6 y107 w80 h20 , Publisher:
Gui, Add, Text, x6 y137 w80 h20 , Year:
Gui, Add, Edit, x55 y17 w380 h20 vContent1
Gui, Add, Edit, x55 y47 w380 h20 vContent2
Gui, Add, Edit, x55 y77 w380 h20 vContent3
Gui, Add, Edit, x55 y107 w380 h20 vContent4
Gui, Add, Edit, x55 y137 w180 h20 vContent5
Gui, Add, Button, x106 y167 w100 h30, Enter ; The label ButtonEnter will be run when the button is pressed.
Gui, Add, Button, x296 y167 w100 h30 , Cancel ; The label ButtonCancel will cancel action but keep script running.
Gui, Show, x350 y182 h210 w461, New Entry
Return ; End of auto-execute section. The script is idle until the user does something.
GuiClose:
ButtonCancel:
Gui,Destroy
Return
ButtonEnter:
Gui, Submit ; Save the input from the user to each control's associated variable.
Gui,Destroy
Send [[%content1%]] (%content5%) *[[%content2%]]*. %content3%: [[%content4%]]`n`n
return
Entry form for bibliographical (Journal ) data
Adapted from the above.
#NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases.
SendMode Input ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory.
#SingleInstance,Force ; Only launch 1 instance of this script.
;~ #Persistent ;Will keep it running...
` & j::
Gui, Add, Text, x6 y77 w80 h20 , Vol-Iss:
Gui, Add, Text, x6 y107 w80 h20 , Journal:
Gui, Add, Text, x226 y137 w80 h20 , Pages:
Gui, Add, Text, x6 y167 w80 h20 , URL:
Gui, Add, Edit, x55 y137 w160 h20 vContent5
Gui, Add, Edit, x275 y137 w160 h20 vContent6
Gui, Add, Edit, x55 y167 w380 h20 vContent7
Gui, Add, Button, x106 y207 w100 h30, Enter ; The label ButtonEnter will be run when the button is pressed.
Gui, Add, Button, x296 y207 w100 h30 , Cancel ; The label ButtonCancel will cancel action but keep script running.
Gui, Show, x350 y182 h255 w461, New Entry
GuiClose:
ButtonCancel:
Gui,Destroy
Return
ButtonEnter:
Gui,Destroy
Send [[%content1%]] (%content5%) '[[%content2%]]'. *[[%content4%]]*, %content3%, %content6%. %content7%`n`n
return
