When in vim-mode, moving the cursor to or from a line with folded content (either sub-points in a bullet lists or a folded section) will often expand it, with the cursor landing in the expanded section.
Enable vim mode.
Create a nested list, and fold the top-level bullets points.
Use j/k or up/down arrow keys to navigate between the top-level bullet points in normal mode.
(Failure happens more often if the top-level bullet points are long enough to wrap.)
The cursor moves between the top-level bullet points.
Often (but not always) the bullet point that the cursor moves to or from will expand (unfold), and the cursor will move to the first or last of the expanded items.
- Operating system: macOS 11.2.1
- Obsidian version: v.0.11.3
