I have some carefully arranged panes and it is far too easy to accidentally click the “close” X in the upper right corner of the pane. Is there any way to disable this as a one-clickable shortcut? I’ve fine with keeping the close pane capability, I just don’t want it appearing in a place where one accidental click can mess with my layout.
I’ve looked through the settings and Obsidian help, and can’t find anything related to this. The closest related article I found in the forums was this one about an “undo” shortcut upon accidentally closing a pane: https://forum.obsidian.md/t/ctrl-z-should-also-undo-close-pane/9712. What I really want is to just not have that shortcut appear at all, but a way to undo would also be helpful - doesn’t look like this other topic was resolved
Not have this “X” icon appear at the top right corner of all my panes. It’s too easy to accidentally click.
