Core Outline Plugin: highlight location of cursor/view
Will be implemented in v1.5 No ETAs.
What will it look like? I’m curious :eyes::joy:
To clarify, this is currently being worked on and will be released at some point in the the 1.5.x cycle.
WooHooo!!!
This is finally implemented!
Changelong says it happened on version 1.5.1
We were a very hopeful and patient group for 3.5 years!
Thanks everyone
Thanks to the Obsidian team for implementing this!
A further request: is there any way to have the outline scroll to sync with the note? Currently, if I click a heading above or below the viewable portion of the outline, I have to scroll the outline itself to find it.
Would it be possible to have the outline snap to my location when I click a heading in the note?
It would be better to either start a new help thread, or if you want to request this, to write out a new Feature requests post, and follow the template.
And I’ll vote for it. I think it would be a very good request!
Including: if you use the command Open outline of the current file, it should scroll to the header position you were at when you ran the command.
Thanks for the tip! Just added a feature request:
