Consistent spacing for reading and editing mode?
Hey all - really quick one. I’m wondering if there’s a way that we can make paragraph/heading spacing in reading mode the same as in editing mode? It just looks really good!
I’ve had a look for plugins that solves this, but it does not appear to exist. I’m currently using the Minimal theme, and also checked Style Settings (plugin), however you can only modify the paragraph and heading spacing for reading mode only.
Thank you!
There are a few different ways of going about this - adjusting only Editing view, only Reading view, and a combination of both with lots of variation in the CSS used.
It really comes down to personal preference and the contents of your notes. Do you just have some headings and paragraphs, or are your notes filled with lists, code blocks, and math equations? The CSS will grow in complexity depending on what elements you want to cover and adjust.
I’d search the forum for some examples to try out. Here are two that you could start with to see how it goes:
Thank you @ariehen! It sounds like there’s no simple way to do this without messing about in CSS, which is fine (but another thing to control/manage/learn), so I’m gonna probably put this one in the ‘not worth it’ basket :smiley:
