Consistent "note context menu" in all features
Right now, there is this context menu available when you right-click on a note in File Explorer:
And a different menu from the note “three-dots” button:
There are two primary requests here:
  1. Combine the two menus to have the same options.
  2. Make this menu available anywhere a note is presented:
    • Search results
    • Graph node
    • Backlinks
And a side comment is that this primary note context menu could be part of the plugin API as requested here:
https://forum.obsidian.md/t/is-it-possible-to-have-a-plugin-to-add-a-custom-command-for-context-menu/1952
It’s not considered as a bug, so a feature request it is:
I see no reason for the right-click menu to be disabled for notes in the search panel: when we find the note we’re looking for it should be expected that we might want to open it in default app or show it in folder etc., no?
