Adding Vim-like Ctrl+J and Ctrl+K navigation to quick switcher as well as Alt+[0-9]
Save this as a .js file and point CodeScript ToolKit to it as your “Startup script path.” It’ll make it so pressing Ctrl+J moves down and Ctrl+K moves up in the default Obsidian quick switcher.
exports.invoke = async (app) => {
	app.workspace.onLayoutReady(() => {
		const switcherPlugin = app.internalPlugins.getPluginById('switcher');
		if (!switcherPlugin?.instance) return;
		const ModalClass = switcherPlugin.instance.QuickSwitcherModal;
		if (ModalClass.prototype.onOpen.__navigationAdded) {
			return;
		const originalOnOpen = ModalClass.prototype.onOpen;
		ModalClass.prototype.onOpen = function() {
			originalOnOpen.apply(this, arguments);
			if (this._extraKeysAdded) {
				return;
			const downEntry = this.scope.keys.find(k => k.key === 'ArrowDown' && k.modifiers === '');
			const upEntry = this.scope.keys.find(k => k.key === 'ArrowUp' && k.modifiers === '');
			if (downEntry && upEntry) {
				this.scope.register(['Ctrl'], 'J', (e) => downEntry.func.call(this, e));
				this.scope.register(['Ctrl'], 'K', (e) => upEntry.func.call(this, e));
				this._extraKeysAdded = true;
		ModalClass.prototype.onOpen.__navigationAdded = true;
If you’d like to also have Alt+[0-9] to switch to a specific quick switcher entry[1], add this directly under the if (downEntry && upEntry) section.
const enterEntry = this.scope.keys.find(k => k.key === 'Enter' && k.modifiers === '');
for (let i = 0; i <= 9; i++) {
	this.scope.register(['Alt'], `${i}`, (e) => {
		const index = i === 0 ? 9 : i - 1;
		const values = this.chooser?.values;
		if (values && values[index]) {
				this.chooser?.setSelectedItem(index, e);
			if (enterEntry) {
				enterEntry.func.call(this, e);
		return false;
I saw this and this. I thought it was so neat how they essentially copied the function that runs when certain keys are pressed and put it under different keys. I then remembered how I accessed core plugin stuff for an audio recorder toggle…
Recently I had stopped using the Quick Switcher++ community plugin and was missing the Ctrl+J/Ctrl+K navigation as well as the Alt+[0-9] to jump directly to a specific file in the list, so decided to bring them back.
Relevant feature request: Ctrl-J / Ctrl-K Hotkey for navigation within command palette and quick switcher - Feature requests - Obsidian Forum
There are some other workarounds in that thread, but they add EventListeners to the entire document which felt like overkill to me.
  1. 0 being the 10th entry. ↩︎
