Using the CodeScript Toolkit plugin, you can put a .js file in whatever folder you set as the “Invocable scripts folder.” Then, you can assign a hotkey to that script[1].
This script toggles the audio recorder.
exports.invoke = async (app) => {
if (app.internalPlugins.plugins["audio-recorder"].instance.recording) {
app.commands.executeCommandById('audio-recorder:stop');
new Notice('⏹️ Recording stopped');
} else {
app.commands.executeCommandById('audio-recorder:start');
new Notice('🔴 Recording started');
Related feature request:
It also is available as an Obsidian command, so you can have other ways of triggering it, too. ↩︎
