Add hotkey for "Focus Sidebar"
Recently, you’ve added the ability to navigate up or down in the sidebar with the up and down keys. However, you still need to click once on the sidebar to “focus” it, which triggers this ability.
(The primary reason many people requested that feature is that they didn’t want to use a mouse at all, while within Obsidian.)
I’m requesting a “Focus sidebar” hotkey. It should simulate a click on the sidebar.
Manually clicking, which is annoynig.
​Iterate through files in the file sidebar with keyboard
You can already set a hotkey for “Reveal active file in file explorer” which will focus the sidebar.
Thanks. That solves this problem, I suppose.
There are several show X commands for this.
I would find this useful in the Starred Files tab as well. Is there a way to do that?
