ezgif.com-gif-maker
Based on the movies and series script proposed by @Christian, this script uses IGDB api to fetch data.
If anyone is interested, here is a link to the Github repo of this script, including a tutorial on how to install.
If the script helped you and you wish to support :wink: :
Please make sure you understand the script before using it, I’m not a programmer so use with caution !
Hey there!
Really cool Idea—I’ve been loving the movies and series script and I’m stoked to get cracking on this.
One issue: I’m getting the ā€œAuth refresh errorā€ message. Some inspection shows that my IGDB Token JSON file isn’t getting created by the script. I know you said you’re not a programmer, but it looks like this is a new/unique section of code compared to the movies and series script, so I wonder if you have any ideas why this could be happening?
I do wonder if there may be an issue with my setup of the Twitch App, if I had to hazard a guess. JSON/API connections are new to me and I was unable to find some clear documentation around Twitch→IGDB, so perhaps the JSON file isn’t being created because the token isn’t being generated in the first place?
If that’s the case, I’d love to see how you set up your redirect. In my case, I just went with the localhost (however I did try plugging in the url of actual v4/games endpoint and that didn’t work either).
Would love to hear your thoughts about what may be going on here!
Problem raised by @bearlythinking has been solved. Please make sure you don’t accidentally add a space when entering client id or client-secret in script configuration.
Added 1.1 :
  • Now possible to fetch developer name and logo (if available on IGDB).
If anyone had trouble getting IGDB client id and client secret needed to run this script, I added detailed steps in the readme on how to obtain them.
New in 1.5 :
  • igdbToken.json is now saved in Obsidian vault’s config directory and not in Obsidian’s system directory.
  • The script should now also run on Mac.
Update 2022-02-08 :
Work is being done to make this script also work on mobile. I need to find a way to use Obsidian API inside a Quickadd script, to replace node.js fs and normalize from path which apparently do not work on mobile.
New in 2.0 :
  • Script should now work on mobile, thanks to QuickAdd 0.5.1 !
  • Fixed a bug where a missing information from IGDB would prevent note creation.
