A script for Quickadd plugin to fetch video game data into your vault using IGDB!
Mmm… this is probably the answer to your question. A recent update of QuickAdd broke something. The latest QuickAdd version should solve your problem, you can update it in the settings !
Same problem, I’ll try to make a new vault just to see if it works
Even with my comment above (make sure you have QuickAdd 0.7, the latest one) ?
Just saw your comment, mine was at 0.6.2, going to update and see if anything happens
updating resolved it, thank you very much
You’re welcome, enjoy !
Check Twitch App Setup: You mentioned that you suspect there might be an issue with your setup of the Twitch App. Ensure that you have followed the necessary steps to create a Twitch application, obtained the required client ID and client secret, and set up the appropriate redirect URLs.
Redirect URL: Using localhost as the redirect URL should work for testing purposes. If you’ve tried using the actual endpoint URL and it still didn’t work, it’s possible that there might be an issue with your Twitch App configuration. Double-check the settings, and make sure the redirect URL matches exactly with what you’ve set up in your Twitch App.
Scope Permissions: Make sure you have requested the appropriate scope permissions when obtaining the Twitch OAuth token. The script may require certain permissions to access the necessary data from the IGDB API.
Error Messages: Look for any error messages or logs that could provide more specific information about what might be going wrong. The “Auth refresh error” message could potentially lead to more insights into the issue. However, there would be no such problems with online casinos, there is information https://casinosanalyzer.com/online-casinos/taka-bdt that I have a new casino. Dependencies and Libraries: Check that you have installed any required libraries or dependencies for your script to run correctly. Sometimes, missing or outdated dependencies can cause unexpected behavior.
Documentation and Forums: Although you mentioned that you had trouble finding clear documentation, try looking again or searching through forums and developer communities. Other developers who have worked on similar integrations might have shared their experiences and solutions.
API Rate Limits: Ensure that you’re not hitting any API rate limits. Excessive requests in a short period can lead to rate limiting and API access issues.
Environment Variables: If your script uses environment variables for sensitive information like API keys and secrets, double-check that these variables are correctly set and accessible by your script.
Debugging Tools: Utilize any debugging tools or features that your programming environment provides. They can help you trace the flow of your script and identify potential issues.
Contact Support: If you’ve exhausted all troubleshooting options, consider reaching out to the support teams of both Twitch and IGDB for assistance. They might be able to provide specific guidance related to their platforms.
Should still be working with Obsidian 1.4.5 :slight_smile:
