I moved a couple of posts into this new thread because they propose a very general way of defining ranges. General is nice but sometimes complex if the problem at hand is narrow.
The syntax for transclusion of range should allow to Exclude first (or last) block/item mentioned in specification of the range.
This would allow to keep adding items to start or end of (sub)list …
… without need to update specification of each transclusion of this (sub)list.
usecases:
- content of the chapter without header
- queue/stack of tasks
- nested (sub)lists
syntax suggestions
- I suggest double period as distinct range specifier. “
” has minimum of other common meanings so it would intuitively explain itself at first glance to many computer literate people. Wikipedia: Ellipsis (computer programming) → Ranges -
![[FileNameORPageURL#^id1..^id2]]
transcludes range starting by block with^id1
and ending by block denoted by^id2
. - Assuming that IDs do not start by hyphen, start/end item would be excluded from the range by prefixed hyphen.
![[pageurl#-^id1..^id2]]
excludes first block from range so items inserted after^id1
are automatically transcluded without need to update references. -
![[pageurl#^id1..-^id2]]
excludes last block from range so items appended to list before^id2
related requests/functionality:
- Header level support for Linking To/Embedding Ranges
- Add Ranges To Header-Level Embeds
- Transclude Range of Blocks
- Date/number ranges within search/filter
- Support sub-list embedding
- Text Fragments
- Preferably many of these would be solved by one consistent syntax.
- The same as in the post above would work for html elements with id attribute (without caret). e.g.
![[pageurl#id1..id9]]
,![[pageurl#-id1..id9]]
. - References to “markdown” block-id and html id can be combined in ranges.
![[pageurl#^md-block-id..div-id]] ![[pageurl#span-id..-^md-block-id]]
- If there can exist/exists element with ID starting by hyphen then we would need e.g. to enclose such ID in parentheses in order to exclude it from range.
![[pageurl#-(-id-starting-by-hyphen)..id2]]
. - This approach is suggested for negative numbers in Date/number ranges within search/filter
Interfering problem:
Reference to chapter is indistinguishable from reference to html block and (perhaps as a consequence) it is impossible to transclude / refer to html block/element with assigned ID.
For example [[pageurl#markdown-chapter-id]]
refering to
# Markdown Chapter ID
Text of the chapter.
is indistinguishable from [[pageurl#span-id]]
refering to html span
markdown text
containing<span id="span-id">html elements</span>
which is standard but does not work in Obsidian.
solution:
I would suggest (before Obsidian 1.0) changing syntax for chapter reference from [[pageurl#markdown-chapter-id]]
to [[pageurl##markdown-chapter-id]]
- This would put markdown headers with associated chapters on the same level as (markdown)-block-IDs with associated blocks.
First#
symbol would always separate fragment from page URL and the second#
would denote header just like^
denotes block. Then we could refer to everything:
![[pageurl#html-element-id]]
![[pageurl##markdown-header-id]]
![[pageurl#^markdown-block-id]]
![[pageurl##first-chapter..#last-chapter]]
![[pageurl#-#intro-chapter..#last-chapter]] where prefixed hyphen excludes introduction chapter from range.
![[pageurl##intro-chapter..-#index-chapter]]
![[pageurl##first-chapter..]] transclusion starts by first chapter up to the end of page.
![[pageurl#-#intro-chapter..]] everything after intro chapter up to the end of page.
![[pageurl#..#last-chapter]] everything up to last chapter (including)
![[pageurl#..-#last-chapter]] everything up to last chapter (excluding)
Possible behavior of references in nested structures:
- useful e.g. for referencing Bible
- Distinguish duplicate id’s via tree structure created by chapters, markdown blocks and html elements
![[bookname##ch1^v5..#ch2^v3]]
- from chapter1/verse(block)3 up to chapter2/verse3 - limit range by boundaries of surrounding (higher level) block/element:
![[pageurl##chapter1..^block-in-chapter1]] would transclude beginning of chapter up to specified block. ![[pageurl#^block-in-chapter1..#chapter1]] would transclude end of chapter starting by specified block.
