A large portion of my obsidian usage is based on bible study, which splits things into obvious blocks (verses). I believe there’s likely others with a similar issues/use case however. My problem is how to handle transcluding a range of verses/blocks which is not necessarily the same each time (ie could be blocks 1-3 first transclusion, 2-6 next time, then 1-8).
For example, for a small snippet would be
1 Forasmuch ... among us, ^1
2 Even as ... ministers of the word; ^2
3 It seemed good to ... excellent Theophilus, ^3
4 That thou ... thou hast been instructed. ^4
I think a simple way to do this would be to specific a “range” in the embed to combine transclusion of multiple blocks. Something along the lines of
![[my_note#^1-3]], ![[my_note#^1^3]], or ![[my_note#^1#^3]]
depending on what characters are currently allowed in block-ids.
Currently usage would look like this,
![[my_note#^1]]
![[my_note#^2]]
![[my_note#^3]]
which is clunky and results in a HUGE amount of space being taken up in preview mode before/after each transclusion (especially if I’m transcluding 10-15 blocks). Further, when navigating to the transclusion, only a single block is highlighted, and it would be great if they all were.
A plugin could also automatically split my proposed solution to this, but isn’t going to solve the clunkiness/space/highlighting issues.
