Add Ranges To Header-Level Embeds
Inspired by dendron:
![[NAME.OF.NOTE#STARTING-HEADER:#ENDING-HEADER]]
Allow explicit ranges for header(and block?)-level embedded links.
Definitely a good idea. Fortunately, there is already some support for it here: Support for Linking To/Embedding Ranges
You may have missed it in your search using the word header as opposed to heading.
Thanks.
Ooh yes – thank you! I will add the syntax ref. there so people know.
(Note to the Obsidian folks: Feel free to close this out in favor of that thread.)
Closed as duplicate of Header level support for Linking To/Embedding Ranges
