1.8.9 seems to recognize quotes `>` as ordered lists, causing incorrect numbering
I will show several specific scenarios below to present Obsidian’s current actual results. The expected results are indicated in the same-line comment.
Y
Expected result & Actual result
Scenario 1, OP: Obsidian Chinese Forum t48758
> 1. item 1
> 2. item 2
> some text
> 3. new item 1 // Hope the index here is 1 but it can't be
Scenario 2, OP: Obsidian Chinese Forum t48455 (Solved in 1.8.10)
> 1. item 1
>     2. indent item 1 // Hope the index here is 1
3. item outside // Hope the index here is 1
Tracking: #4 for 1.8.10. (The scenario 2.1 mentioned in #5 comes from here)
	Obsidian version: v1.8.9
	Installer version: v1.8.9
	Operating system: Windows 11 Home China 10.0.22631
	Language: zh
	Base theme: light
	Plugins installed: 0
	Plugins enabled: 0
May be related:
You can try to add a ”- “ before some text:
It is not a workaround, but I hope it can ease your pain. :smiley:
Moreover, this issue may be related to:
@GLight Yeah I posted it in the second place of Additional information as well before.
Let me add a little more. The analysis provided by the original poster of that post may not correspond to this issue, cause this kind of format has always been just a list.
1. item 1
2. item 2
1. item // can't be. It's in the same list so must be 3.
But a blockquote is a separate block, which differs from this. Since the bug reported by the poster and the analysis look like 2 different cases, I’m not sure which one the “would fix” in the official reply referred to. For Obsidian, the former is an issue, while the latter is more like a manifestation of the basic Markdown syntax. Still, thank you for actively providing suggestions.
1.8.10 Tracking:
  • Scenario 1: Still exists
  • Original Scenario 2 given in #1: Solved :tada:
    > 1. item 1
    >     1. indent item 1 // √
    1. item outside // √
  • Derived Scenario 2.1 of Scenario 2: Still exists
    1. before block item 1
    > 1. item
    2. after block item 1 // Hope the index here is 1
	Obsidian version: v1.8.10
	Language: zh
	Catalyst license: insider
	Base theme: light
	Plugins enabled: 0
Scenario 1 is this Numbered Lists do not properly reset while inside callouts
Please open a separate bug report for scenario 2.1. Thanks.
@WhiteNoise Thank you. Previously, there were users continuously posting similar threads on the Chinese forum, so I created a summary post. At that time, I also suggested that they should report on the English forum in the future. I may not actively follow up on the subsequent situation. Out of a sense of responsibility, I will stop doing it on their behalf for now. Thank you again for your reply.
