- In a new note, create a callout.
- Inside the callout, create a numbered list and fill it with any items.
- Move a few lines down within the same callout and try to create a new numbered list.
- Observe that the new list continues numbering from the previous list instead of starting at 1.
- Even manually correcting the numbering (e.g. changing
4.to1.) does not work — it automatically resets to the wrong continuation value.
Y
The new list inside the same callout should start at 1), as it is a separate list.
The new list continues numbering from the previous list (e.g., starts at 4) instead of 1)).
- Obsidian version: v1.8.9
- Installer version: v1.8.9
- Operating system: Windows 11 Pro 10.0.26100
- Login status: not logged in
- Language: en
- Insider build toggle: off
- Live preview: off
- Base theme: adapt to system
- Community theme: none
- Snippets enabled: 0
- Restricted mode: off
- Plugins installed: 0
- Plugins enabled: 0
- none
