I have tested this on a clean Obsidian build.
If you type , all following code blocks denoted by the backtick (`) or the triple backtick (```c++) will no longer render as code blocks in edit mode.
Preview mode works.
Inserting any sort of punctuation in between the < and > symbols allows it to render them as code blocks.
We do not support intermingling HTML and markdown notation.
You can have an HTML block within mardown but that is it.
