I love the app! It’s the best clipper I’ve tried so far.
I just wanted to make a suggestion: in order for this to work more seamlessly with Obsidian, the extension’s clipboard should convert html header tags into markdown syntax when using the Obsidian preset. Right now, it is copying headers as <h1>Header</h1>, but Obsidian works better when you use the markdown syntax, which is # Header 1. That way, the title will render in both edit and preview mode. I left a feature request in GitHub with screenshots and more details.
I’ve never used Roam, but I’m guessing there’s a reason to use the html syntax there. I just hope you can include this html-to-markdown conversion for Obsidian without messing with the default Roam mode. Thanks a lot in advance!
